![]() Join Date: Jan 2001
Can Anyone Desktop Dyno My Combo?
I am trying to dial in my 402 with the Megasquirt EFI system I built and installed and I need some fairly close HP & torque figures I can plug into the VE map and finish setting it up. If anybody has a Desktop Dyno that can help me out I would greatly appreciate it!
Heres the scoop: Stock bore 402 Stock CR (9.0:1?) Comp Cams XE250H cam (470lift/250dur Intake 475/260 Exhaust 110 degree center) 600-4800 RPM range Performer dual plane intake. Sock oval port heads Stock exhaust manifolds w/ dual pipes Did I miss anything?? Thanx! |
68cst_ss490
what size carb are you running????
Dean edmonton,canada a winter wonderland 2005 Chevrolet Avalanche LT cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers. http://www.cardomain.com/ride/3090973 |
I have a 2bbl TBI from a 454 on it. Twin 51MM bores with 85lb/hr injectors.
68cst_ss490
I got about 308 hp @ 4500 rpm and 401 ft/lbs @ 3000 rpm. the numbers hould be slightly higer though. there isnt a spec for throttle body injection. if you throw a set of headers on ther you should get closer to 340 hp and 435 ft/lbs
Thanx Deano!!
