Old 05-23-2005, 01:34 PM   #1
mhicks
mhicks's Avatar
Length of Driveshaft?
Going to install a new 350 in a '73 short stepside with a 700r4. Does anyone know the length of driveshaft I will need? Would be nice to have it made before I start the process.
mhicks is offline   Reply With Quote
Old 05-23-2005, 01:59 PM   #2
hotrodhomi
hotrodhomi's Avatar
some shops measure the length diffrently. Its best to call the shop you plan to use and ask how they measure it. You don't want to order the wrong size.
hotrodhomi is offline   Reply With Quote
Old 05-23-2005, 06:50 PM   #3
jermasaurus
jermasaurus's Avatar
I went from a TH350 to a 700R4. I did not need my driveshaft legnth modified. As long as the 350 has the 9" tailshaft, I am pretty sure the legnth should be close enough (3/4" shorter than a 700R4 I believe)
jermasaurus is offline   Reply With Quote
Old 05-23-2005, 10:16 PM   #4
bigarmzz
bigarmzz's Avatar
i had a drive shaft made last winter for another truck project of mine....the machine shop here that makes custom drive shafts measures from center of rear u-joint to center of front u-joint to determine the length they need.
1987 350 TBI lowered 5/7
bigarmzz is offline   Reply With Quote
Old 05-24-2005, 01:09 AM   #5
jermasaurus
I hear you also slide the yoke into the trans all the way, and pull it out one inch (with the truck resting on the suspension).
Old 05-24-2005, 09:11 AM   #6
fade94
fade94's Avatar
MHICKS: I sent you a PM
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates)
67 short step project (will get SWB from the 68)
67 Camaro, #'s matching (my wife's)
03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear
fade94 is offline   Reply With Quote
Old 05-24-2005, 09:13 AM   #7
fade94
fade94's Avatar
I have drive shafts for both short and long tail. Sent you a PM.
Old 06-01-2005, 01:50 AM   #8
jimfulco
A Turbo 350 with the 9" tailshaft housing (used in '73-up Chevy LWB trucks & Suburbans, maybe some SWB's too) is the same length as a 700-R4. Except if the 700 came from a Corvette.
jimfulco is offline   Reply With Quote
