05-23-2005, 05:12 PM | #1 |
Wheels are stuck to the hub.
Alright guys I've gone and gotten my wheels stuck literaly. I'm simply trying to remove the rims/tires from the front of my 72' chev 1/2ton 4x4. The truck has "Selectro" manual hubs. I've removed the 6 lug bolts and have become boggled as to why the wheels will not budge. I've got the front of the truck on jackstands with 1" clearance under the tires and I've sprayed the rim to hub area with WD40. Any ideas?
Thanks, Josh
72Chevy swb 4x4 71GMC swb 2x4 |
05-23-2005, 05:19 PM | #2 |
Member since 2000
When wheels got stuck from god knows what. We just planted our foot on the top. Kick it in other ways. kinda like if you were stomping on someones face.
Sometime sjust punching the top section then the bottom of the wheel works. kinda work it side to side. Last edited by Alexis; 05-23-2005 at 05:19 PM. |
05-23-2005, 05:25 PM | #3 |
Progress = 0%
If the truck is in running condition, reinstall the lug nuts but back them off slightly so they aren't seated on the rim. Drive the truck around the block while turning the steering wheel from side to side (like you are trying to warm up the tires in a NASCAR race). That should break them loose.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
05-23-2005, 05:37 PM | #4 |
its all about the +6 inches
I would hold off on Slammed idea (where you been slammed...I thought you were gone). Put the truck back on the ground, place the lug nuts on, but again, only 1/2 way on the studs, and then grab the side of the truck and shake it from side to side with all you got. I broke some free on the longhorn that had sat for more than a couple years.
Also, a sledge to the inside of the rim (if steel) will work, but if you get stupid with it, you will bend the rim. If all this fails, THEN go around the block...carefully. The studs aren't as strong as we like to think, and can (probably will) snap if the rim pops off the hub and you don't realize it and keep on doin the nascar/ricer tire heating thing. |
05-23-2005, 05:42 PM | #5 |
Born a Chevy Man
I agree with Longhorn Man. I would not drive it around the block myself.
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66 *1986 Chevy SWB Silverado *1984 Chevy Longbed Silverado New Kia Sportage (Wife's car and she loves it) CHEVY, American made w/pride! If you can read this, YOU NEED TO THANK A TEACHER! If you can read this in ENGLISH, PLEASE THANK A SOLDIER! GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS |
05-23-2005, 05:48 PM | #6 |
Progress = 0%
OKay, I'm not talking about going 60 mph around the block! Tighten the lugs then back them off maybe 1 turn so they are about finger tight. Drive it slowly down the street. I did this with my grandma's Cutlass after every other attempt failed. Worked like a charm. No guts, no glory
05-23-2005, 06:13 PM | #7 |
I work in a shop all day long ... and I would NOT suggests Slammed67's idea. If its a steel wheel ... jack it up .. put it on jackstands ... and smack the wheel with a sledge hammer. You can beat on the damn tire all day and it wont budge.. been there done that ... and we dont like to have to replace wheel studes if ya dont need to. If its not a steel wheel I would suggests some PB Blaster .. spray around the centers and let it set awhile. More than likely they are just stuck around the centers.
05-23-2005, 06:41 PM | #8 |
I have had this happen on mine, and what we did was put it up on jackstands, start the truck, put a block between the wheel and the frame or somethin like that and turn the wheel until it popped off.
1970 Chevy CST/10 1970 Chevy CST/10 1972 Chevy C/10 1972 Chevy Suburban K/10 2019 Silverado 2500 Duramax Kevin |
05-23-2005, 06:43 PM | #9 | |
Seņor Member
Picture of his grandma's car below...
05-23-2005, 07:00 PM | #10 |
Update,
So far I've done the kicking of the tire method and using a sledge hammer with a block of wood (these are steel wheels). So far no budge. Now I've gone and got a can of PB and I've sprayed em good. I'll let them sit for a while to let the oil soak in then I'll try the sledgehammer method again. Don't think I'll take her around the block just yet. But I might put the lug nuts back on loosely, and try setting her back on the ground and rocking the truck back and forth while turning the wheels. Josh
05-23-2005, 07:19 PM | #11 |
I'm watching you!
XXL
2012 Chevrolet Silverado 1500 Z71 4WD 1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP) 1992 Chevrolet S10 - LS swap project 1968 Chevrolet C-10 longbed fleetside - sold |
05-23-2005, 08:16 PM | #12 |
stuck wheel
I loosen the lugs just a little, then turn the wheels lock to lock a few times, interrupted by a few raps with a large brass mallet. When you do get em off, sand or wirewheel the center hole, then apply a little axle grease to the edges of that hole, and a little to the backside.
05-23-2005, 08:51 PM | #13 |
I don't think putting axle grease on his backside is going to help much.
What exactly are you thinking 3 on the tree...wait, I don't think I want to know
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
05-23-2005, 10:20 PM | #14 |
Now the others dig........
That happens to my rear wheels, I just use a long bar (which I keep in my truck) between the rubber and the trailing arm and pry it off. you may want to try that up front ....maybe off the steering knuckle....not sure how it would work on the front however......or sell it and buy a Ford......
just kidding....
68 Chevy C10 Stepside Black Primer 78 GMC Longbed White 09 Chevy Silverado Shortbed Granite Blue LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala MEMBER OF THE DRUM BRAKE CLUB Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX Certified Music Educator I hope Mom is up there watching and being my Guardian Angel "I've got a fever.....and the only prescription.....IS MORE COW BELL" -The Legendary: Bruce Dickenson "F#$@ 'em up!!!!!!" -The Legendary: Rogelio Escobar TRUCKY LINKS http://67-72chevytrucks.com/vboard/s...d.php?t=457750 http://67-72chevytrucks.com/vboard/s...d.php?t=461184 http://67-72chevytrucks.com/vboard/s...d.php?t=472848 http://67-72chevytrucks.com/vboard/s...d.php?t=417541 http://67-72chevytrucks.com/vboard/s...d.php?t=477788 Last edited by SWINGSAX68; 05-23-2005 at 10:20 PM. |
05-23-2005, 11:34 PM | #15 |
I'm with Slammed67 on this one. Although it will usually be free by the end of the driveway.
'68 Short Step LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc |
05-24-2005, 10:52 AM | #16 | |
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
05-24-2005, 07:05 PM | #17 |
Did you get the wheels off?
05-24-2005, 11:23 PM | #18 |
Some steel wheels have threaded holes that hold the center caps on.
You can run some longer bolts through these holes and push the wheel away from the hub. I've used this trick on badly rusted on wheels with good results.
"Negative people always seem to have a problem for every solution" |
05-24-2005, 11:36 PM | #19 |
I had one that would not come off no matter what until I rednecked it. Take a sissor jack and put between tire and frame and then just engage the jack until it pops off. It worked for me when everything else would not.
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together) |
05-25-2005, 12:28 AM | #20 |
Professional Grade
I just took my 12 pound sledge and went nuts on the wheel. I didn't care about the wheel, so I just aimed for the top of the wheel on the outside and gave it a full swing as hard as I could. Two blows and it came off, along with badly bending the wheel, lol
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
05-25-2005, 08:11 AM | #21 |
Livin' it up.
Do you have an impact hammer? that would honestly shake the daylights out of things so much that things should come off... assuming you don't rattle the rest of your suspension into unhappiness. Anyways yeah, i'd not go with Slammed's idea... but the beating/soaking thing should work... just give it heck
-Greg; Sold the 69 C20. It's off to a better home with more love! Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires. |
05-28-2005, 12:40 AM | #22 |
Hey guys I'm back..
Just got back from a training seminar in Salt Lake city. I was able to get those wheels loose finally. I think I ended up making 3 trips around the block to get em broke free. Thanks for all the help guys! Josh
06-18-2005, 11:12 PM | #23 |
The old pain in the butt stuck tire.Ihave had that happen to me more than once and what Ihave done and it has worked ever time for me is support the truck on jack stands take the spare tire and throw it at the bottom of the stuck tire as hard as you can sometimes it takes two or three times but this has worked ever time for me. 8bolt
06-19-2005, 04:00 AM | #24 |
After sitting for 16 years my cousin's caprice classic had a front wheel stuck on. After soaking, beating & prying for 10 minutes it came off. Later we found we had bent the hub & rotor... another trip to the local yard $15, $9 to have the rotor turned. An expensive lesson I'll not soon forget.
06-19-2005, 06:27 AM | #25 |
I can not believe no one mentioned a little heating up the steel rim around the center.
Heat does wonders to help loosen things up, just like a little Jack D. to warm up the little woman, LOL!
1968 Chevy 4x4 307 4 speed |
