Old 05-24-2005, 11:22 AM   #1
iluvmy72
Is a Carter 600 enough for a 455?
I am wondering if my Carter 600 is enough for the big block 455. It was fine on my 350 but the 455....I don't know.
iluvmy72 is offline   Reply With Quote
Old 05-24-2005, 11:27 AM   #2
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
I don't think it would be, I sure somebody will chime in with some more solid advice.
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 05-24-2005, 11:33 AM   #3
dtlilly
dtlilly's Avatar
I wouldn't think so either, even if you jet the 600 up.
dtlilly is offline   Reply With Quote
Old 05-24-2005, 11:43 AM   #4
67chevemall
67chevemall's Avatar
you need AIR on a big block!
Theres a 800 on ebay that is sweet! It is on another post here.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 05-24-2005, 12:55 PM   #5
screamin_c102
screamin_c102's Avatar
NO, the CFM rating is the amount of air the carb can flow. The larger the engine displacement the more air needed to maintain a proper air/fuel ratio. Just jetting it up will increase the amount of fuel introduced into the engine, which will actually throw off the air/fuel ratio even worse.
Use a 750 CFM at least, or some of the older big block Quadrabogs were actually flowing 795 CFM.
The nice part about the Edelbrock/Carter carbs is that due to their variable venturi you can put a huge carb CFM wise on a smaller (or less needy) motor and jet it to run fine. As you change cam profiles and or CR you only need to adjust jetting.
Just my $.02
screamin_c102 is offline   Reply With Quote
Old 05-24-2005, 05:57 PM   #6
72BLAZERDUDE
72BLAZERDUDE's Avatar
You need at least a 750 CFM on that big block. I have a Edelbrock 1406 on my 307 and that is a 600 CFM carb.
72 2wd 307/AT/AC/TILT WHEEL
78 JIMMY HIGH SIERRA
72BLAZERDUDE is offline   Reply With Quote
Old 05-24-2005, 06:02 PM   #7
GMC AMI
GMC AMI's Avatar
Wink
NO
1968 Chevy 4x4 307 4 speed
GMC AMI is offline   Reply With Quote
Old 05-24-2005, 06:19 PM   #8
flip66
flip66's Avatar
I was told by Edelbrock tech that a 600cfm is almost too small for a 396 so I would think that 600 would way to small for 455
1998 Pontiac Grad Prix GTP
1969 C10 396 TH400 3.08 posi
flip66 is offline   Reply With Quote
Old 05-25-2005, 07:43 AM   #9
Bowtie67
Bowtie67's Avatar
Interesting!! Nascar engines putting out considerably more HP & RPM and have restricted their cfm's to I believe under 500CFMs. I have a friend who has a built 383 with a tunnel ram running 1 Holley 390CFM 4 barrel and claims he can smoke the tires up while cruising and gets some pretty good gas milage in his 38 sedan. Although you wont reach any peak HP numbers with the 455 and this carb but if it is just a cruiser it may work fine, I would just bring it to someone who can make sure the air fuel ratio is proper.
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears
1948 Chevy FleetMaster Coupe, LS1, (almost done)
1950 Chevy StyleLine Coupe 250/6 3x2 Dueces
2009 Toyota Tundra
1996 Harley RoadKing
"I maybe getting old, but I can still burn rubber with the best of them"
Bowtie67 is offline   Reply With Quote
Old 05-25-2005, 10:47 AM   #10
GMC AMI
GMC AMI's Avatar
Wink
[QUOTE=Bowtie67]Interesting!! Nascar engines putting out considerably more HP & RPM and have restricted their cfm's to I believe under 500CFMs.
That would be to Level the playing field! If you put a 455 in a truck who in their right mind would restrict the BB like that! Sure it will run OK and so will a 283 CI. IMO go for at least a 750 double pumper min., 455 is no wimpy motor so FEED THE NEED!
Old 05-25-2005, 10:57 AM   #11
flip66
flip66's Avatar
True NASCAR does run on restrictor plates but the motors are built just for those races to do that they do not use the same thing on all tracks. I could be wrong but in the plate races they do not need much torque you need more CFM and fuel to get torque.
Old 05-25-2005, 01:05 PM   #12
68Stepbed
68Stepbed's Avatar
It depends on how your 455 is built. Is it stock or modified? On a stock 455 it should be fine. If it is modified the 600 may not flow enough air and may starve the engine. It's not how big the carb is as much as how the A/F mixture is according to the amount of air going through the carb. I have an article that a guy states that he took the 390 Holley off of his 302 and put it on his 460 and the jetting was perfect. I have a friend that drag races a 66 Fairlane with a 390 and he uses a 600 Edelbrock. When he switched to a 750, it ran worse. The extra cfm's are only useful in high rpm applications. Carbs don't usually flow full cfm ratings at cruise speeds.
I would try the 600 and if your not satisfied then try something bigger. I would try a 750 vaccum secondary Holley or a 650 mechanical secondary.
Just my 2 cents. Let us know what happens.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 05-25-2005, 03:34 PM   #13
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Yeah, it really depends on how much you beef up your 455 or keep it stock. I think if its mainly stock a 650 would work good or even if its beefed up try running I think 670 but I can"t remember who makes one of the top of my head.
Later
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 05-25-2005, 05:14 PM   #14
Tom
driving is in my blood
Tom's Avatar
NASCAR's get away with it because they make up for the power in other area's, namely heads and cam. Also don't forget they tune the intake for a supercharging effect, that helps up the flow of that little 500cfm carb a bit.
Old 05-25-2005, 09:13 PM   #15
ed455
Captain Ed
Some of the old Mopar 383's and 440's in the big Newporst and New Yorkers had Holley 600 carbs on them. Small carbs make for good low end power which is what those big barges needed.
ed455 is offline   Reply With Quote
Old 05-26-2005, 12:54 AM   #16
krue
Designated A-hole!
krue's Avatar
If you have the carb already, throw it on there. If it don't work you're not out anything.
If it does then you haven't bought a carb you don't need.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 05-26-2005, 03:29 PM   #17
Fred T
Cantankerous Geezer
Fred T's Avatar
For a stock engine, yes. Figures out to 631 CFM.
http://musclecarsusa.com/prods/carburetion/info.html
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 05-28-2005, 06:22 AM   #18
'68OrangeSunshine
'68OrangeSunshine's Avatar
I used to have a 454 in a '67 K/10 Suburban. The PO put it in. Nothing fancy, just a junkyard transplant, so very likely stock. PO also had a Carter AFB 9635. It ran good so I didn't change it. The truck would cruise the freeway at 80 like a walk in the park. I always thought it was a 750 CFM carb, but it turned out to be a 625 CFM. The Edelbrock match is an EDL 1400.
Old 06-06-2005, 01:59 AM   #19
Ogier
Chopper/Painter
Ogier's Avatar
Exclamation
Yes. This will work just fine on your 455.
I just love it when the "bigger is better" crowd comes out to play. Carberation is a science not a guessing game.
What will happen if you go much bigger than a 650 is the bottom end will get soggy and the midrange will seem to go away.
My personal favorite carb for the street is the good old Holley model 1650 600cfm universal carberator. They are extremely tune-able and contrary to popular belief, can and do get great milage when set up for the vehicle.
Incidently, I used to run this same carb on my Stage II 455 Buick and could smoke the tires till they blew without brakes... :hit2:
just my .02$
With regards,
Ogier
1969 Chevrolet C20 - Resto-Custom started!!!
Ogier is offline   Reply With Quote
Old 06-06-2005, 05:41 AM   #20
GMC AMI
GMC AMI's Avatar
Sure the motor would run with a 500 two bbl as well but who would want that? With a 455 you do not need to worry about bottom end with all that torque. If you think a Buick stage 1 or 2 came with a 600 from the factory you are sadly mistaken, they can easily handle a 750 double pumper. I ran a 455 Buick in a 80 vette body at the drags
and I never saw any soggy botom end or any lacking mid-range. The Vette ran 7.2 at 92 mph in the 1/8 th mile with stock 308 gears right off the street. Even Caddy BB's came with a much bigger carb than a 600. Now why would GM do that?
Old 06-06-2005, 06:47 AM   #21
Ogier
Chopper/Painter
Ogier's Avatar
Exclamation
True, the carbs that came out of the factory were _rated_ at higher CFMs, however, they were almost always Rochesters which are a pseudo-variable venturi carburetor and shares much more in design with the Predetors than with Edelbrocks, Carters, or Holleys.
The Rochester does _Not_ open up completely when you stab the throttle. It will only open as much as the engine can handle based on the amount of vacuum present in the manifold dictated by the RPM of the engine.
Thus, comparing the CFM rating of a Rochester and that of a Holley is rather like apples and oranges.
If you use a 750cfm Holley, Carter, or Edelbrock on a street driven vehicle you will likely have a soggy bottom end, crappy gas mileage and whitewashed cylinder walls.
Of course, I may just be blowing smoke out of my ass but having built in excess of 250,000 total horsepower in my life in engines ranging from lawnmower engines to 1200hp blown drag motors, I rather think that I am likely not.
I have said it before and I will again, Carburetion is a science. Bigger is usually not better.
Again, just my .02$
With regards,
Ogier
Old 06-06-2005, 07:10 AM   #22
GMC AMI
GMC AMI's Avatar
Wink
True on vac. secondary models, not mechanical secondarys which will open when you stab the throttle. I was using a 750 Holley double pumper on the 455 in the Vette.
It would truley pin you back in the seat from the so called soggy bottom end, maybe in your application, just was not true in mine.
Old 06-06-2005, 07:33 AM   #23
70c10
67-72 Addict!
70c10's Avatar
I would personally run a 750. I have been in a few cars with stock 455 motors that had 750 carbs that would burn the tires off the car. I have a buddy with a 455 in his GTO and he runs a Dominator but that's another story
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 06-06-2005, 02:24 PM   #24
crm318
Alright Alright Alright
crm318's Avatar
i think a good running qjet will suffice
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 06-06-2005, 02:42 PM   #25
Ogier
Chopper/Painter
Ogier's Avatar
Exclamation
Actually, even with the mechanical secondary Rochesters, the top set of butterflys don't open right away. They open with manifold vacuum.
Here is a page that talks about carburation done properly using a Holley. The same goes for Edelbrock and Carter carbs.
In the end, the person who owns the rig must decide what they want. There are questions that must be asked though before a proper recomendation can be made like how are you planning on driving the rig? Is this a race engine or a daily driver? Is gas mileage a factor?
With regards,
With regards,
Ogier
