05-24-2005, 03:24 PM | #1 |
1/2 vs. 3/4 ton?
I seem to remember reading a while back that the 3/4 ton trucks have boxed frames, where as the 1/2 ton trucks have the c channel frames, is this correct? and I know that the two variants run different axles and springs, but can anyone give me more specifics than that?
05-24-2005, 04:19 PM | #2 |
'68 C-20 396 CST CC
Larger brakes-- pads, wheel cylinders, and brake springs (not sure about the master cylinder--the front spindles are different as well...larger hubs (8-lugs)...
Along with larger spindles and axles (Dana 60,70 and Eaton rear ends) The wheel bearings are larger on those components as well to handle more load. I know my 3/4 ton has a heavy-duty stabilizer bar and a rear end stabilizing link that isn't on my 1/2 ton. I'm not sure about the frame differences though...
68 C-20 396/TH400 CST Custom Camper NOW W/DISC BRAKES 01 Jetta Turbo Daily Driver 84 Yamaha Virago 700 - Alaska to Florida Via Maine & Mexico |
05-24-2005, 04:35 PM | #3 |
I've seen several trucks that have been switched from one to the other, so if there are differences they must still be compatable with the other's running gear.
Nik |
05-24-2005, 05:10 PM | #4 |
The frames are basically the same, 3/4 tons aren't boxed.
Bob
V-6....only GMC Trucks have it! 62 GMC W5000 NAPCO-V6 65 GMC 2500 NAPCO Panel-V6 66 GMC 1000-V6 66 GMC 1500-V6 67 GMC K1500-SBC (originally a KM-V6) 68 GMC C1500-V6 68 GMC C1500-V6 68 GMC Suburban C2500 70 Chevy K20-SBC 71 Chevy C30 Longhorn-SBC 72 GMC Suburban C1500-BBC 72 Chevy C10-SBC 72 GMC C5500-ToroFlow Diesel |
05-24-2005, 05:23 PM | #5 |
I believe the 3/4 Ton Chassis have a couple angled braces between the side rails and the crossmember that the driveshaft passes through. There was a picture in a thread several months ago.
05-24-2005, 05:26 PM | #6 | |
'68 C-20 396 CST CC
I keep hearing different things about the frames...my 1/2 ton frame doesn't look any different than my 3/4 (both '68s). One guy on this board once wrote that they used thicker steel in the 3/4 but I can't tell a difference. Anyone ever read anything "official" on this in any GM publication?
05-24-2005, 05:35 PM | #7 |
December 21, 2012
My 3/4 ton frame isnt any different than by 1/2 ton frame. Front end parts and the rear end are heavy duty compared to 1/2 ton and thats about it.
"!Ama Sua, Ama Kjella, Ama Lllulla!" |
05-24-2005, 07:02 PM | #8 |
its all about the +6 inches
The 3/4 ton has some bracing that the 1/2 ton doesn't. That is it as far as frames.
The trailing arms on a 3/4 ton are stronger. |
05-24-2005, 07:38 PM | #9 |
huh ???
I know the front brakes on the front of my 72 C/20 uses the same D52 brake pads as my 86 K/10...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
05-24-2005, 08:13 PM | #10 |
same frame stronger "gusets" on the 3/4 ton.
rear end is bigger and so is the brakes
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
05-25-2005, 10:51 AM | #11 |
Post Whore
The GM restoration packet indicates the C10, C20, K10 and K20 frames all use 39,000-lb-test steel. The C10 frame section modulus is 2.98 while a K10 frame section modulus is 2.70.
The C20 frame section modulus is 3.71. The K20 frame section modulus is 3.48. I found this definition of section modulus: Section Modulus - A measurement that is calculated based on the shape of the cross section of the rail (what the frame rail looks like when it’s viewed from the end). A tall rail made of thick material will have a higher section modulus than a short rail made of thinner material. Additionally, adding an insert will increase the section modulus of the rail. Section modulus has a direct effect on the stiffness of a rail.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
05-25-2005, 10:57 AM | #12 |
Any mention of the section modulus for a C30?
05-26-2005, 02:16 PM | #13 |
Post Whore
My restoration pack unfortunately only address the 1/2 ton and 3/4 tons.
05-27-2005, 12:08 PM | #14 |
Will they do a restoration pack for a C30?
05-27-2005, 09:49 PM | #15 |
There's hardly anything about C20's in the resto pack I got. It covers mostly C10s, but I have a lot of the dealer manuals and parts books for the 10 thru 60 series trucks, this is the most recent book I have, got it for free too!
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
05-28-2005, 07:22 AM | #16 |
Here's a link for alot of frame info/specs for ya.
http://www.chuckschevytruckpages.com/framespecs.html |
