Old 05-24-2005, 04:53 PM   #1
superchevy
Got big-block?
superchevy's Avatar
who's installed a Sanden a/c compressor in their 73-87?
I just did, and was wondering how to wire it up to the factory a/c compressor harness. Any help appreciated.
SC
'68 CST SWB factory 396/T400
buddy buckets, a/c, ps, pb
'72 Corvette convertible 454/4spd/ac, ps, pb
'73 GMC Sierra Grande short wide 454/T400 ps, pb, ac
'77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original
'78 GMC Sierra Classic short wide 454/T400 ps, pb, ac
'72 GMC Sprint SP454. 1 of 38 built.
'73 GMC Sprint SP454. 1 of 71 built.
'75 GMC Sprint SP454. 1 of 25 built.
SOLD! '72 GMC K25 4x4 468/4L80e/NP205
build thread
http://67-72chevytrucks.com/vboard/s...23#post4324423
SOLD!'55 Chevy gasser 496/4spd
build thread
http://67-72chevytrucks.com/vboard/s...96#post4324396
superchevy is offline   Reply With Quote
Old 05-24-2005, 06:20 PM   #2
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
I installed mine in '94 and just connected the compressor lead up to the existing wire for the compressor.
NeCrOmAnCeR is offline   Reply With Quote
Old 05-25-2005, 10:23 AM   #3
454HO
I don't have a Sanden compressor yet, but I am going to use one on my BB project... I already have the Alan Grove bracket for it. I was under the impression the only electrical connection was the clutch. Is there also a pressure switch? Which model Sanden are you using? The model number I am looking at is #4509.
- Greg
454HO is offline   Reply With Quote
Old 05-25-2005, 11:12 AM   #4
78SilveradoSWB
78SilveradoSWB's Avatar
Happen to have the Alan Grove part number? Thinking about using a Sanden too.
Mitch
1978 Chevrolet Silverado C 10
454 BB, TH400
78SilveradoSWB is offline   Reply With Quote
Old 05-25-2005, 03:03 PM   #5
454HO
I am using part number 122R for the a/c because I want to move the compressor to the passenger side. This should help clean up the engine bay a bit since ALL the a/c components and hoses will be on the same side. Of course this means I need to move the alternator to the driver side, so I also got part number 222L. These parts numbers are for BB with long water pump.
- Greg
Old 05-25-2005, 06:17 PM   #6
superchevy
Got big-block?
superchevy's Avatar
I'm using the AG brackets as well. Really nice stuff. Fit perfect.
As far as the Sanden goes, my compressor just has the one black lead coming off the clutch...guess I'll just splice it to the factory compressor's power wire and ground it to the bracket. I'm leaving everything else as factory...including the presure switch on the drier.
SC
build thread
build thread
Old 05-25-2005, 06:25 PM   #7
454HO
Hey SC, did your brackets come painted or did you have to paint them yourself? Please post a report on how the Sanden works when you get everything going.
- Greg
Old 05-25-2005, 08:48 PM   #8
superchevy
Got big-block?
superchevy's Avatar
The brackets were unpainted.
I'll post when I get the a/c recharged.
SC
build thread
build thread
Old 05-25-2005, 11:05 PM   #9
NeCrOmAnCeR
Like I said above, I installed mine in '94, and it has worked great. I changed over to 134A at the same time I installed the compressor. Used a kit from Vintage Air which included everything except the evaporator. I wanted to use all the factory air controls and ductwork. The system has worked perfectly, going on the 11th year. I can try to take some pictures of my set-up as my brackets are much different.
Old 05-25-2005, 11:21 PM   #10
Bowed
Where do you get those Alan Grove brackets ? Thanks .
Bowed is offline   Reply With Quote
Old 05-25-2005, 11:34 PM   #11
454HO
Alan Grove Dealers
I bought mine from Yogi's
- Greg
Old 05-27-2005, 08:29 PM   #12
superchevy
Got big-block?
superchevy's Avatar
Well, I got the new A/C lines made, new drier and orifice tube. We flushed the condenser and evaporator, and vacuumed/charged up the compressor with 134a...no leaks and everything works great...blows real cold, though not as cold as the R12 that was in there before, but still, cold enough for me. I thought the big block might run a little hotter, but it stayed right at 200 degrees all day today in 90+ heat and stop and go traffic...that big-ass 4-core radiator does get the job done.
Sweeeeet...will be a cool summer.
Oh yeah, I just spliced the black power wire from the Sanden comp to the factory green a/c comp wire...no ground...pressure switch as factory and works fine.
Later, SC.
build thread
build thread
