Old 05-24-2005, 09:45 PM   #1
Rakort
FA: Custom Camper Special Aux Rear Wire Harness
http://cgi.ebay.com/ebaymotors/ws/eB...tem=4552445640
This is a factory wire harness that came as an option on the 1967 to 1972 camper special trucks. This is a somewhat uncommon wire harness that I believe is not reproduced. This harness plugs into the tail light harness on the firewall and to the positive terminal node located on the fender near the battery. There is also a white wire that connects to either the engine block or firewall for the ground. This harness then runs along the frame rail and up through the bed of the truck for providing direct battery power to back of the truck for use in a camper. The harness also provides an additional set of tail light wires for camper attached tail lights incase your camper covers your factory tail lights. The positive and ground power wires are heavy gauge wire (~ 10 gauge) so you should have no problems running power hungry 12 volt accessories in the camper.
This wire harness is in fine shape. The harness was disassembled, cleaned, inspected, repaired as needed (quality soldered connections with heat shrink tubing applied), and rewrapped. The harness has all of the factory ends still in place. No repairs were required on the factory plugs / ends. This harness has years of service left in it.
I charge actual shipping fees, no bogus "handling" or "packing" fees like some of our ebay friends.
Rakort
Rakort is offline   Reply With Quote
Old 05-29-2005, 12:52 PM   #2
Rakort
Option Code
As you can see in this picture this was option code UY1 - Camper Wiring
http://69.23.95.47/stuff-for-sale
Old 05-31-2005, 08:49 PM   #3
Rakort
Last call!
