05-25-2005, 06:14 PM | #1 |
WTB Rear seat rear legs??
Have the front mounts, rear legs are broken as if the seat got folded back once. Makes for a scarey ride, any help???
05-25-2005, 06:22 PM | #2 |
SKINNY TIRES RULE!
Does your seat take 2 or 4?
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
05-25-2005, 06:51 PM | #3 |
Seat Legs.....
Just Two, can't find extra holes on the frame??
05-26-2005, 11:31 AM | #4 |
SKINNY TIRES RULE!
Not all of them have four holes in the frames. If it only has two, the center belts bolt directly to the floor
05-26-2005, 02:06 PM | #5 |
Thats it....
Now finding a trashed frame with good legs. Any source on new seat belts???
05-26-2005, 02:42 PM | #6 |
SKINNY TIRES RULE!
No repro Blazer belts. You either need to find some good used ones, or slap in some lame aftermarket belts.
05-27-2005, 05:51 AM | #7 | |
May be able to come up with some legs if you haven't found any yet. |
05-27-2005, 05:57 AM | #8 |
No luck Yet...
What would you need for the legs? Probably will go with aftermarket black belts. BTW love your truck, what is your tire and wheel combo???
05-27-2005, 06:05 AM | #9 | |
On the legs, what 'exactly' do you need? The front hoops or the rear feet? Maybe all? |
05-27-2005, 07:03 AM | #10 |
Rear Feet
Rust and mine look like the seat has flipped backwards once. I have one front hold down, making another till I find an original.
05-27-2005, 07:30 AM | #11 | |
I'll go up and check for ya today. |
05-27-2005, 07:59 AM | #12 |
2
Just two......
05-27-2005, 09:04 AM | #13 |
I might have something that will work also...in my search I came across something that will do. I compared them to Blazer rear brackets in my 70 and there 1/4 inch taller if that. Not sure if they are different between years or not. Dont have a selection of blazers to compare with. Also seat belt bolt holes may be necessary in your application..which I think mine have..have to go look.
05-29-2005, 06:36 AM | #14 |
I have two complete blazer rear seats, both w/4 legs.
Front hoops/rear legs/arm rest bars all are good, no rust/bends. Need the whole seat? |
05-29-2005, 07:24 AM | #15 |
PM sent
Message sent
