Old 05-26-2005, 12:51 PM   #1
72c5
72c5's Avatar
Got a 69 Rearveiw Mirror w/ Maplight, how replace blub?
Seems like a dumb question, but I cant figure out how to get the bulb holder out of the bottom of the mirror. Ths clear plastic lens pops right off but does not open a big enough opening to remove the bulb.
I had a 71 Skylark w/ a maplight; and on that mirror, the whole slider unit popped right out of the base.
On this mirror it feels like the old, brittle, plastic parts are gonna break if i try to pry the unit out of the mirror base.
On this 69 Chevelle mirror the bulb has a metal snap on diffuser that keeps the bulb from falling out the access hole with the lens popped off......
BTW for you Blazer guys, the mirror map light is great when the top is off.
72c5 is offline   Reply With Quote
Old 05-26-2005, 04:10 PM   #2
smonty
Smonty
Maplight Mirror
I have one like yours and the light works if you want it. $35.05 shipped. I looked at it and it looks like you have to take the mirror class and gasket off. Notice the little clip at the top of the mirror. I would be scared to take it off too unless I was going to replace the mirror and gasket coz it will probably chip or tear the plastic when you try to remove it. Ernie
72 2WD Blazer
68 SWB Fleetside
67 SWB Stepside
2005 Chevy 1500HD Crewcab
56 Chris Craft Mahogany Runabout
Looking for 36 Chevy 1/2 Ton P/U Project
smonty is offline   Reply With Quote
Old 05-27-2005, 07:21 AM   #3
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Very easy to do. Pop off the lens, then gently squeeze the side of the lens holder/slide switch together and pull out. (squeeze the thin sides together)
The bulbs are easy to find, just dome light style bulbs.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 05-27-2005, 07:24 AM   #4
72c5
72c5's Avatar
awsome! thx, i figured it had to be something like that.........was trying to pry from ends, that was not happening........
Have a great weekend!
Old 05-30-2005, 09:26 PM   #5
72c5
72c5's Avatar
Bob- thank, that was a snap! Done!
