Old 05-26-2005, 07:58 PM   #1
Syco67
Red face Need some help from those with PS.
A fellow board member was kind enough to hook me up with the parts to convert my sisters 69 3/4 ton GMC to PS. I was wondering if anyone had some pics to post or send of there PS installed. I am still unwise in the ways of GM wrenching, I have always had fords. I'm not biased by any means, just always seem to end up with them. (Please don't hate me.) I really like this GMC, I take care of it for my sister, she only has room for 2 of 3 cars at her place, so I keep it at my house and get to drive it occasionally to maintain it.
If at first you don't succed, break something!
Syco67 is offline   Reply With Quote
Old 05-26-2005, 08:50 PM   #2
JimKshortstep4x4
Talking
Here are a couple of pictures of the steering box and hoses. It is pretty hard to show the pump as it is pretty low on the engine.
Jim
Old 05-29-2005, 03:51 AM   #3
Syco67
Thanks, it does sit pretty low, I scraped off the gunk and found the 2 mounting holes. I have the pump mounted on the block now, but the pulley on the pump sits too far back to line up with the crank pulley. Is it okay to use a pulley puller and move the pulley forward a little bit? it's only off by about 1/2 the width of the pulley.
P.S. Hey Teeitup, thanks for sending that extra balancer bolt, mine turned to crap when I reinstalled it after swapping pulleys, totally trashed the threads, I was able to clean the hole and use the bolt you gave me.
Old 05-29-2005, 06:58 AM   #4
70GMCer
70GMCer's Avatar
What year set up is that for? The setup I have on my 70, came off a 71 PS truck and the hoses are ran differant. Are all 67 to 72 PS hoses run the same way?
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 05-29-2005, 07:02 AM   #5
JimKshortstep4x4
Talking
Do you have a cast crank pulley on the engine? It sounds like the pump and crank pulley may be different years.
Pulling the pulley forward is not a good idea. You may be able to fix the problem if you can locate a pump pulley with a different offset as there are different pulleys.
Jim
Old 05-30-2005, 09:40 AM   #6
Syco67
The crank pulley is a 2 piece setup, a flat pulley for the alt. belt, and the other pulley bolts to the front of the first one, but sticks out a little further.
