Old 05-27-2005, 12:23 AM   #1
Nima
Blue 67
How do I measure my rear brake ?!
Hi eveherybody:
As some of you may know, I will change my front brakes to disck soon. The only part which is missing is booster,mc and pp valve. When I look at the different websites, some of them ask for 13 or 11 inch rear brake. How do you measure that? is it the diameter of the drum? if yes, the diameter inside (after taking the drum off) or outside? By the way mine is C20, maybe they just come with 13"? Thanks.
Nima is offline   Reply With Quote
Old 05-27-2005, 03:34 AM   #2
68LSS1
68LSS1's Avatar
I think when dealing with drums it's the internal diameter of the drum. When dealing with rotors it is just the diameter of the rotor.
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
Old 05-27-2005, 08:18 PM   #3
3 on the tree
Size should be stamped into the brake drum: something like Max Diameter 11.03 in. kShould be stamped on the flat face of the drum.
3 on the tree is offline   Reply With Quote
Old 05-28-2005, 02:49 AM   #4
OhioDan
OhioDan's Avatar
Thumbs up
When I did mine, I had to measure the length and width of the lining on the brake shoe. Some are 11" X 2", and some are 13" X 2 1/2". Hope this helps?
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 05-28-2005, 03:50 PM   #5
Nima
Blue 67
Thanks guys. any info helps.
