05-27-2005, 10:27 AM | #1 |
vin tag location
is the vin tag located in the same general spot in all of the 67-72 chevys, looked at a 71-72 chevy and didnot see the vin tag by the door latch. it did have a rectangled hole there go long ways vertical. thought the this might be for the cab pressure valve.
would like to know for sure if this cab is worth usin. best cab ive seen around here.
'67 chevy on '79 K10 frame Metallic Grey-Fleet White top 35in Ground Hawgs 355 ci, SM 465, NP 205 "A Dying Breed...Classic Chevy" |
05-27-2005, 10:57 AM | #2 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
I believe the only place the VIN tag is located is on the drivers door jam.
I know the VIN number can be found in a few different places on the frame but the only tag was in the drivers door jam.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE Last edited by BobbyK; 05-27-2005 at 10:57 AM. |
05-27-2005, 11:23 AM | #3 |
it not the original frame its a 69 frame, newer 12 bolt and 44f axles, its got 39.5 gumbos on it dont know lift but i think he said 6in. (talked to the owner before i seen the truck and after i had a few drinks)
what year did the cab pressure vents start???
05-27-2005, 11:59 AM | #4 |
I'm not that familiar with the pickup cabs but I don't think they appeared untill at least 73.
Don't quote me though.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
05-27-2005, 12:01 PM | #5 |
Maybe someone just cutout the VIN plate so as to keep those special rivits intact.
05-27-2005, 02:07 PM | #6 |
I know 72 cabs had the black plastic air vent in the drivers side of the cabs door jam, I can't remember if 71 had them or not. You need to have the vin tag on the cab... why was it removed? Where is it today? Makes me wonder if the cab came off a stolen truck, and the tag removed.
05-27-2005, 04:21 PM | #7 |
70 - 72 used a 4 vin rivets....the tags have some difference in the script also between the years.
72 cab has no rear view mirror hump in the cab roof. |
05-27-2005, 10:24 PM | #8 |
its all about the +6 inches
The vent in the dvr door jamb started in 71.
67 - 69 had 2 seperate plates, one VIN and one GVW (IIRC) 71 had a one year only trait, there was a raised mounting pad in the metal over the windshield for the rear view mirror. |
05-27-2005, 10:47 PM | #9 | |
The LuvShack Garage
Wtf does that last word mean, j/k w/ ya
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
05-28-2005, 12:14 AM | #10 |
The 67-69 vin and gvw is on the one plate...the other plates some compliance tag or something like that cant remember off top of head.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
05-28-2005, 10:19 PM | #11 |
What if you want to take the vin plate off and polish it while you paint the truck? Can I get new vin rivets? Do you think it would be ok to use regular rivets?
05-31-2005, 03:43 PM | #12 |
the vent must been missing but didnt see the vin tag either, he might have takin it off because he started to repair cab and primed spots. I didnt look at the mirror i was in a hurry and its was in somebodys yard not his. i was thinkin he said it was a 72, i might see him this weekend at a party so ill ask him.
dtlilly the truck is in southren Ohio. ill get back with you guys if he doesn't have a title or vin tag.
