Old 05-27-2005, 10:27 AM   #1
67chevemall
67chevemall's Avatar
Temp sensor install ??????
Hello
Just wondering if I need some teflon tape on the temp. sensor and oil
sensor fittings??
67chevemall is offline   Reply With Quote
Old 05-27-2005, 10:32 AM   #2
stllookn
Saving 1 truck at a time!
stllookn's Avatar
It would not hurt to use it since it will help seal and will help reduce corrosion when or if you need to replace them. I use them on mine and they seal really well.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 05-27-2005, 10:53 AM   #3
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Yes.The sensor will prob. leak without the teflon tape.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 05-27-2005, 11:36 AM   #4
67chevemall
Thanks guys!
Now I just need to buy the big wrench to fit down behind the Alt.
Must be a 15/16?
Old 05-27-2005, 12:53 PM   #5
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
Wait a sec... The temp sensor uses a pipe thread and teflon should not be required. Install finger tight + 1 turn. The teflon may interfere with the ground path of the sensor if you use a lot of it.
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 05-27-2005, 02:53 PM   #6
67chevemall
Thats how I have it now - the wrench turn.
If it leaks I'll try tape.
Thanks again
Old 05-27-2005, 03:30 PM   #7
68haywagon
I'm watching you!
I used some blue silicone gasket sealer on the '93. No leaks yet and the sensor seems to be working right. I had a 99cent pack from AZ laying around and thats all I could find.
Mike
2012 Chevrolet Silverado 1500 Z71 4WD
1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP)
1992 Chevrolet S10 - LS swap project
1968 Chevrolet C-10 longbed fleetside - sold
68haywagon is offline   Reply With Quote
Old 05-27-2005, 03:36 PM   #8
67chevemall
So maybe just a bit of blue gooo around the top.
Old 05-27-2005, 03:41 PM   #9
chickenwing
No, I do not think it is dum. You are just risking whether or not you get a good ground. If it works that is great. If it doesn;t work you'll be draining coolant... again.
Old 05-27-2005, 04:13 PM   #10
BobbyK
BobbyK's Avatar
one turn of tape won't effect the ground,there's plenty of thread for a good ground.Like chick said,don't use too much.
Tape is just a little insurance against leaks.
I personnally wouldn't use the blue gasket maker though.Nothing against anyone who does...I just wouldn't.
Old 05-27-2005, 05:17 PM   #11
68haywagon
I'm watching you!
Thats all I had laying around and I didn't have a car around to go running out. I had to improvise and it seems to be working. When I removed the old sensor it had a orange substance on the threads. I didn't know what it was so I figured what the hey orange, blue its all the same to someone colorblind .
Mike
Old 05-28-2005, 05:39 AM   #12
68LSS1
68LSS1's Avatar
I'm with chickenwing. most sensors now-a-days come with a sealant already on the sensor. If your reinstalling a used sensor you can get "sensor safe" RTV but I wouldn't use teflon tape. I'm sure a lot of people have and do but why chance the gage accuracy?
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
Old 05-28-2005, 06:45 AM   #13
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Take the sensor and hold it up looking at it real close in the light. The threads are tapered. Pipe fittings require NO sealant on them. They use pipe thread specificly for that reason.
Old 05-28-2005, 07:46 AM   #14
lost wages
lost wages's Avatar
when i first fired up my truck the temp gauge did nothing, after alot of searching it was the the teflon tape on the sensor, had to drain the block and clean all the tape out. I wouldnt use any tape.
lost wages is offline   Reply With Quote
Old 05-30-2005, 09:27 AM   #15
67chevemall
Well I put the darn thing in then out then in then out then in with blue goo
Now I have to take it out because I need a different sensor for gauges.
Oh what fun it is.
