Old 05-27-2005, 05:19 PM   #1
teamharvey
teamharvey's Avatar
Window help
I am in the middle of rebuilding my doors and all is going well until now. I am having a very hard time getting the window back in. I replaced the regulator and can`t get the rollers back in the channels.
I have the roller for the door channel in and can get the rear roller in the window channel, but I can`t get the front roller to match up with the opening in the window channel.
I am hot, tired and bleeding !!
71 Custom 20 Deluxe..soon to be SWB 1/2 ton
1 incredible wife
2 great kids
teamharvey is offline   Reply With Quote
Old 05-27-2005, 08:46 PM   #2
krue
Designated A-hole!
krue's Avatar
Have you tried rolling the window up or down a little? Also do you have the regulator bolted to the door (it's the last thing I do). Leave it unbolted and roll up or down a little. I try to save the back one for last (it's just got to go in a notch in the window frame). It's aggrivating but sooner or later it will go. Good luck.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 05-27-2005, 08:52 PM   #3
71-longbed
Its Magically Delicious
71-longbed's Avatar
Just did this today.. heres a great link http://67-72chevytrucks.com/vboard/s....php3?t=157539
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 05-27-2005, 10:42 PM   #4
teamharvey
teamharvey's Avatar
OK, window is in, regulator rollers in channels. Now I can`t get the vent back in. The window is all the way down but it is too tight to get the window into the vent channel. Seems like the window needs to be moved back to make clearance. I have the regulator unbolted as well.
Help !
PS....I tried taking the window out of the door channel and wedged it back a bit for some room, but then the front regulator roller pops out and I am back to square one.
Sorry, but this is all brand new.
1 incredible wife
2 great kids
Old 05-27-2005, 11:13 PM   #5
71RestoRod
71RestoRod's Avatar
Putting my regulators and vents in again was like a prize fight... I would beat on it, go sit in the corner and sweat, and then go in and beat on it again. Mine are really tight because I've got power window regulators and I mounted crank switches directly to them.
Try unbolting the channel at the rear of the door... the two bolts at the bottom. Then loosen the one bolt at the top above the latch. You can move it back some and this can give you a little more wiggle room to get the vent window in, and the side window in the vent channel.
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod
71RestoRod is offline   Reply With Quote
Old 05-27-2005, 11:21 PM   #6
neonlarry
neonlarry's Avatar
You are not hot, tired or bleeding enough yet for them to go in, I told you unless someone has a good tip they are a PIA. I know this doesn't help but just keep trying you will eventually get them in. By the time you get around to doing it again you will have forgotten what a bi**h it was.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 05-27-2005, 11:27 PM   #7
teamharvey
teamharvey's Avatar
OK guys, I need a beer then I will hit it again.
Bret
1 incredible wife
2 great kids
Old 05-28-2005, 12:43 AM   #8
teamharvey
teamharvey's Avatar
That was the tip I needed !! What a PITA !! Now the passenger door tomorrow. Thanks everyone, I learn so much from all of you.
Bret
1 incredible wife
2 great kids
