Old 05-27-2005, 05:33 PM   #1
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Wink I learned something about .......
Well a while back I made a post about "GQ" having issues after short trips,
it would die and smell like gas, like it was flooded, today we figured it out,
and this will blow you away, at least it did me, so I carried it Wednesday
afternoon to get my exhaust ran, 15 minutes into my 22 minute trip, you
guessed it, she died, after about 10 minutes she started and I got her in
to the shop w/out any other issues, Thursday we ran the exhaust, there
is a thread w/ pic's for this on this board, Today we bled the brakes and
tried to figure out the issue I was having, so we adjusted the fuel press.
regulater from 8.5 down to 6, drove it around the block w/ out any issues
but it was a short trip, like 5 minutes, so I suggested we check the timing,
10 minutes into the timing thing she died, oops I almost forgot, she was
giving us 25 degrees at idle and 60 degrees of total timing, wtf ???, any
who, she would run a lil, we would try to pull the timing down and she'd
just die again, and everytime it died it reaked of fuel, like mentioned in
my first thread a while back, after 2.5 hours of adjustments, flooding,
and timing issues it finally quit / would not start, we had lost all spark,
started checking every lil spot for spark issues and low and behold the
coil had detenated, top was blown half way off, it was so hot that you
could not even hold it w/out gloves, that's hot, so we called and got
us another MSD BLASTER 2 coil and you guessed it, she purs like a lil
tiger, cranked her up on 2 degrees of timing, set her at 8 degress w/
a 30 degree total timing, now she runs better than ever, what a day
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 05-27-2005, 09:47 PM   #2
wingman
That is weird I think I keep blowing my hei coils. I crank it it try to start then dies, and nothing no spark nothing, and im getting 12v at the distrib when cranking. I changed the coil, drove it around turned it off went to restart it, no spark. Good thing I got the ignition system to put on, now i jsut need to buy a new distrib.
wingman is offline   Reply With Quote
Old 05-27-2005, 10:14 PM   #3
71RestoRod
71RestoRod's Avatar
Congrats on the fix. Are those things oil filled? Did it make a mess?
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod
71RestoRod is offline   Reply With Quote
Old 05-27-2005, 10:18 PM   #4
jhow66
jhow66's Avatar
Have you got this ground strap--if not that is what burning up your coils.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 05-27-2005, 10:32 PM   #5
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
JHOW66 - Is that HEI only, because mine doesn't have a strap
Old 05-28-2005, 08:32 AM   #6
Yukon Jack
Post Whore
Yukon Jack's Avatar
Congrats on getting that figured out.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 05-30-2005, 01:22 PM   #7
jhow66
jhow66's Avatar
If you have HEI-yes
Old 05-30-2005, 05:45 PM   #8
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Originally Posted by jhow66
If you have HEI-yes
Nope, freak'n unilight
Old 05-30-2005, 07:55 PM   #9
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Glad you figured it out. So, then, GQ is amost finished?
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 05-30-2005, 10:00 PM   #10
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
