Old 05-27-2005, 09:33 PM   #1
cornutz
All Praise RANDY!!
cornutz's Avatar
1.5 vs 1.6 roller rocker ?'s
Can someone explain the major diff's between the two...
You see, I want to put a nice mild roller motor in the burb, and I would like to know what the deal is with the two... they seem to be very close, ie: one tenth off right? Also, why do some people on flea bay have sets for sale that have half 1.5 and half 1.6 ratio... Do they use one for the intake and one for the exhaust? and why do that?
Anyway, like I said I want to put in a hyd. roller cam, rocker, lifter setup into the balanced block that I have on an engine stand in the the garage, but I have never tried this route...any help would be appreciated, Thanks.
cornutz is offline   Reply With Quote
Old 05-27-2005, 09:45 PM   #2
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
i am not a pro, but do know that the 1.6 rockers allow the valves to open farther. then you have to make sure that your springs wont coil bind and your valves wont hit the pistons. as far as a mixed set. no idea
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 05-27-2005, 10:12 PM   #3
68Stepbed
68Stepbed's Avatar
Give Comp Cams a call. compcams.com
They have a CamHelp line that you can call. There is a section in What's your problem in this month's issue of CarCraft. I would question the mixed set myself.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 05-28-2005, 07:18 AM   #4
vtblazer
vtblazer's Avatar
My understanding is by putting the 1.6's on the exhaust, their looking for better performance.
Heard of it but never tried it.
I have the 1.5 full roller rockers on a 350 in my blazer and always wondered if by putting in a set of 1.6's they'd be noticable/worth while installation.
vtblazer is offline   Reply With Quote
Old 05-28-2005, 08:23 AM   #5
Harold Shepard
With the 1.6 you make the cam think that it is a little bigger and the Sb chevy exhaust flow with stock heads is not that great, so the rockes cause the illusion of more duration on the exhaust side causing a bit of performance increase. This is not a seat of the pants increase that will be felt but will show across the board on a dyno. Big and small, it helps a little with exhaust flow. Usually a mixed set sells for more $ than a straight set. Harold
Harold Shepard is offline   Reply With Quote
Old 05-28-2005, 08:37 AM   #6
VetteVet
Msgt USAF Ret
VetteVet's Avatar
1.6 rockers
Here is a link that should help with your question.
http://www.chevyhiperformance.com/te...148_0207_rock/
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 05-28-2005, 09:27 AM   #7
Old Yeller 1970
DON'T TREAD ON ME
Old Yeller 1970's Avatar
When I was having my 350 rebuilt, I discussed having 1.6 rockers installed with my engine rebuilder. He said that since I was choosing a cam with lots of lift, there was no need for the 1.6 rockers. In other words the effect I wanted from the 1.6 rockers was being built into cam. He said that to then add the 1.6 rockers would increase the overlap more and cause my bottom end torque to suffer.
The cam in question was a custom ground 280 Magnum Comp cam with a 114 degree lobe separation angle instead of the more narrow one.
After you pick your cam then you should be able to decide, based on where you want your power band to be, whether or not to have 1.5 or 1.6 rockers.
Old Yeller 1970 is offline   Reply With Quote
Old 05-28-2005, 02:25 PM   #8
cornutz
All Praise RANDY!!
cornutz's Avatar
Thanks for the replies guys... I appreciate it...
Old 05-28-2005, 08:30 PM   #9
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
1.5 or 1.6 thats the question
check out car craft mag. july 05 addition there a article in there covering this exact question
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 05-29-2005, 12:05 AM   #10
68Stepbed
68Stepbed's Avatar
I have the 1.5 full roller rockers on a 350 in my blazer and always wondered if by putting in a set of 1.6's they'd be noticable/worth while installation.[/QUOTE]
I've heard that changing from 1.5 rollers to 1.6 rollers, you would only pick up a few horses. Not enough to justify the expense. On the other hand, changing from a stock 1.5 to a 1.6 roller, you could pick up about 10-15 ponies.
Matt
Old 05-29-2005, 01:04 PM   #11
RPOZ11
72 BB C30 Super LongHorn
RPOZ11's Avatar
I am using 1.6 Comp Cams roller tip steel rockers on my 305 in a 1984 C-10. The influence I see is that you can use an aggressive cam up to .500 and still keep some vacuum on the Brakes system. The only time I see any difference is in the top end and I have a 700R/4 behind the 305. I think I like the 1.6 on the exhaust side on cams under .500....Just my experiences!
72 BB C/30 Longhorn Super
HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM
HO72 build :
http://67-72chevytrucks.com/vboard/s...d.php?t=714492
2017 SS
RPOZ11 is offline   Reply With Quote
