05-28-2005, 03:43 AM | #1 |
Professional Grade
Progress
Getting closer!
However, I am screwed as far as the serpentine setup goes. My TPI intake will not work with it at all. Not only will the base not fit, but the throttle body will hit the tensioner smack dab in the center. So I guess this setup is for sale, and it is time to find a setup off a 4.3 or a 3rd gen Camaro... I'll post more pictures when I've got things figured out.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) Last edited by Russell; 05-28-2005 at 03:46 AM. |
05-29-2005, 01:45 AM | #2 |
Professional Grade
Alright, now I've got something to show you guys
Tell me what ya think!
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
05-29-2005, 01:52 AM | #3 |
lookin good Russ
05-29-2005, 02:06 AM | #4 |
North Coast, baby!
Now that is professional grade!
Brad 79 Scottsdale C20 350/350 3.73's Still running full CA smog gear! |
05-29-2005, 02:07 AM | #5 |
Chevys Kick A$$
Ya, progress is looking very good. What all else do you need to get finished up and squared away?
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER I would rather push a Chevy then drive a ford!!
05-29-2005, 02:12 AM | #6 |
Professional Grade
As far as rust repair goes, I gotta patch the pass side floor pan, and coat it. Gotta sand down and self etch prime the roof / some other surface rusted areas, then shoot the cab with epoxy primer, then she'll be good to go back on. Frame needs the rear to be sand blasted, or wirebrushed. I haven't figured that out yet, its tough getting the angle grinder between the frame rails.
As far as parts go, I need a two peice aluminum serpentine belt setup with the power steering pump, AC compressor and tensioner. I need to get my divorced t-case here, get driveshafts made (I am gonna run it with a 2wd shaft until I can afford the driveshafts, at 200 a pop, I need to spread the cost out a bit) and I need a 2wd tranny crossmember with the high arches on either side to clear the exhaust. Any pre 79 truck should have one. Also need brake lines from the splice under the cab to the rear end and the hard lines on the rear end. Also need a driver's side fender Things to do yet include installing and plumbing the EFI burb tank, installing the TPI electrical harness, change the rear drums out to the HD drums from my old 14 bolt and a couple other small things I can see myself with it running by the end of the week if all goes as I want it to
05-29-2005, 05:22 AM | #7 |
man, that looks really sweeeeet!
what did you paint your frame with?...that dont look like a spray can job... good job russell!
1987 350 TBI lowered 5/7 Last edited by bigarmzz; 05-29-2005 at 05:24 AM. |
05-29-2005, 10:13 AM | #8 |
yeller
Russell, your progress looks super....good job man!!
Keep us updated with your progress, can't wait to see it all come together.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
05-29-2005, 12:45 PM | #9 |
Professional Grade
I coated the frame with a product called Zero Rust. My only complaint is that the stuff dries too quick in the sun, and doesn't smooth out :P
I'll probally give the axle and such another coat just to try and smooth it all out a bit I am VERY impressed with it's durability though! I accidentally bumped the top of the frame with the bobcat bucket, and it didn't even scratch it! Its a sort of a softer coating that bends and stuff to absorb impacts. I am gonna buy another gallon so I can do the under side of my bed, fenders etc. The half gallon I've used has coated most of the bottom of my cab, and most of the front suspension I can definitely finish the cab and the frame with the single gallon. Box and stuff will need another gallon :P
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) Last edited by Russell; 05-29-2005 at 12:47 PM. |
06-01-2005, 11:54 PM | #10 |
Professional Grade
Got my cab on tonight, dang its tall
4 and a half coke cans of clearance
06-02-2005, 12:00 AM | #11 |
needin' money
if you don't mind me askin, where did you get the zero rust stuff, and how much $$$ did it cost?
06-02-2005, 12:22 AM | #12 |
Professional Grade
I bought it off a forum member for about 45 bucks shipped, if I recall right...
You can find a distributer at www.zerorust.com. Just gotta email them, and they'll let you know where to find it
