Old 05-28-2005, 02:43 PM   #1
phanatic32212
It's Done When It Runs!!
phanatic32212's Avatar
TV Cable TH350
Can I buy a TV Cable gasket and only the gasket at a local parts house? I found after I cleaned off the tranny, that is where it is leaking from. THanks in advance.
Or Give Me DEATH
phanatic32212 is offline   Reply With Quote
Old 05-28-2005, 02:47 PM   #2
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
i dont see why not. call and ask. easier than driving down
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 05-28-2005, 03:10 PM   #3
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Please excuse the dumbness, What does TV stand for?????
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 05-28-2005, 03:36 PM   #4
phanatic32212
Nope, no one has one. They dont even have the assembly with a gasket for it. I just bought some gasket maker. Cheaper than buying from TCI. TV is the Throttle Valve on the transmission.
Or Give Me DEATH
Old 05-28-2005, 03:44 PM   #5
Smitty
Smitty's Avatar
If for some reason the homemade one doesn't cut it. (no reason why it shouldn't) try a transmission shop such as Valley Transmission in El Cajon. They may have a spare laying around and I know that Richard out at the one on Washington street is great to work with! ne:
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
Old 05-28-2005, 10:01 PM   #6
53burb
53burb's Avatar
A 350 doesn't have a TV cable. It has a kickdown cable on the passenger side. The 700 has a TV cable on the driver's side. Maybe the parts stores do have it, but were looking for the wrong part.
53burb is offline   Reply With Quote
Old 05-28-2005, 10:05 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
53burb, I was about to say the same thing. Over drive trannys with a cable (700R4 and 200 4R) use a TV cable, the non overdrive trannys, excluding the TH400, use a kick down cable, or detent cable.
Even so, i would just use some good sealant like the right stuff.
Old 05-28-2005, 11:39 PM   #8
phanatic32212
Oops, some people do call me an idiot. I guess it was a kickdown cable instead. Either way, I think I got it sealed up pretty good. I guess we'll find out tomorrow when I put some fluid in it. Thanks for the heads up, though. I've been searching for a good tranny shop around here. Do they have decent prices?
Or Give Me DEATH
Old 05-29-2005, 12:56 AM   #9
70c10
67-72 Addict!
70c10's Avatar
I got my detent seal at the Chevy dealer. Part number is 1262475
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 05-29-2005, 07:10 AM   #10
JimKshortstep4x4
Talking
70c10,
Does the seal that you got from the dealer look like a top hat? (Like a tube with a flange). I need one and have been having trouble finding it.
Jim
