Old 05-28-2005, 02:57 PM   #1
Holley Truck Avenger Carb
Does anyone have one of these?Do you like it?It sounds like a good thing,is it?I`m thinking on getting one next time I need a carb for one of my 4wds.How are they off-road?
Old 05-28-2005, 03:29 PM   #2
Mudder
Mudder's Avatar
I have one but have tken it off for other issues. never really got a chance to "use" it. Friend of mine said that you can get everything from Holley to make others like it pretty easy. Splash is the big thing.
Mudder is offline   Reply With Quote
Old 06-03-2005, 01:57 PM   #3
Chevy Muscle
< 69 Blazer
Chevy Muscle's Avatar
This is second hand, but I've read on other fourms that it's great but needs a lot of tuning to get it to run right and then more tuning from time to time to keep it running.
I'm interested in the Edelbrock Thunder AVS 4x4 carb (1826) but I've only heard from one person that has used it and I would like other opinions too.
Chevy Muscle is offline   Reply With Quote
Old 06-03-2005, 11:47 PM   #4
I didn`t know about those Thunder AVS 4x4 carbs.Another one to ponder.
Old 06-04-2005, 10:11 AM   #5
Devil'S Ride
Im runnin the 800cfm Thunder AVS. The carb is nice. Easy to drop on, and its an edelbrock, so it takes all of two screws to adjust it. Unfortunately right now the carb is outta tune and the truck has a stumble off idle. However, it does run much better than my 780cfm holley did when I get off road. The truck no longer has issues over bumps an hills. I love holley carbs, but I think they need to stay in the area they were designed for: The strip. Straight lines are where you want a holley. not off road. But all in all the thunder AVS seems to be a good choice. Just my .02$
The Devil
1983 ONE TON 454/400/208 11" of lift on 44's
Devil'S Ride is offline   Reply With Quote
Old 06-23-2005, 08:47 AM   #6
a1gatorz
a1gatorz's Avatar
I'm running the Elde Thunder series { 650- manual choke} Ran great right out of the box, havn't touched one adjustment srew ! It's been on for over six months. Try changing step up springs to pink for off idle stumble,worked for me on my performer carb I had preiveously? a1tgatorz@comcast.net
a1gatorz is offline   Reply With Quote
Old 06-23-2005, 10:35 AM   #7
gn4u2c
gn4u2c's Avatar
I have a 770 elec choke holley truck avenger. Required little tunning and has "held the tune" perfect. I'm not sure why everyone busts on the holley it makes the most power and is very easy to tune as long as you understand how a carb really works. I have had my truck in some serious tricky spots and no bog or hesitation from it at all. when I say tricky I mean getting 3 people to hang on to the side of the bed to keep it on the wheels !!!! Let me know if you need any help tunning we are close.
gn4u2c is offline   Reply With Quote
Old 06-23-2005, 02:19 PM   #8
ryan68
Certified Chevy Man
ryan68's Avatar
I tried a Holly 650, Truck Avenger 670 and 770 and an Edelbrock Performer 795, all of which sucked offroad. The 795 Edelbrock was the best of them all. The Truck Avenger was more worthless than the Holly 650 street carb In my opinion. I eventually just went back to the stock Rochester Quadrajet on my suburban and it's the best thing I ever put on it. I wheel the crap out of my suburban and all thsoe other carb just crapped out on inclines and angles but I've never had a problem with the old stock Rochester. Don't waste you money and changing lines to put some new crappy carb on your truck.
68 Chevy CST (327,TH400) 3/5 drop lots of fun stuff
71 Suburban 4x4 (350,TH350) 7" lift 37's, D44/14 bolt and other sorts of goodies, lockers front and rear, flexes 40", 895 RTI score
Check out my web site!!! http://www.geocities.com/cst68chevy/
ryan68 is offline   Reply With Quote
Old 06-25-2005, 02:30 PM   #9
I`ve had Q-jets crap-out.Aren`t Edelbrocks Webers?Before the corporate name games,Edelbrock only made the thing the carb sits on and Holley made the carb.
Old 06-25-2005, 02:47 PM   #10
Mudder
Mudder's Avatar
I believe the Edlebrock came from Carter. Carter Carb was bought out by someone in the 80's. You can still get the Carter AFB and if ya notice it looks just like an Edlebrock.
Old 06-26-2005, 04:47 AM   #11
Mudder
Mudder's Avatar
Update.... Federal Mongal (Sp) bought Carter Carb. Edlebrock bought the rights from Carter or Federal to build their carb. Guy at work knew some about it and staightened me out.
Old 06-26-2005, 05:50 AM   #12
Maybe it was only the first Eldys,but I also saw Weber on the body of one.Since they offer multiple carb types,it`s all possible.Thanks Mudder for your facts,I`m always learnin`something here.That`s what it`s all about,eh?
