Old 06-16-2002, 07:26 PM   #1
dnelson
starter wire question
just got a new starter for my 350 and im wondering where the yellow wire and purple wire go or does it matter
71 K5 Blazer 4x4
72 chevy custom delux 10
danny_nelson24@hotmail.com
Craig, Mo
dnelson is offline   Reply With Quote
Old 06-16-2002, 08:06 PM   #2
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
Hmmmmm
The purple wire goes to the 'S' terminal on your solenoid coil.....if you are looking straight at the solenoid coil there is a big bolt for the + battery cable, to the right should be a small bolt....that should be the 'S' terminal for the ignition switch. the yellow wire I think is for point ignition only. if so thats all I know right now...I forget were stuff goes....If you have a electric ignition the distributer needs to run straight to the ignition switch. Find the dist. wire from the back of the ignition switch, cut it and splice a wire from it back to the BAT. terminal on the distributer. Be sure to connect both parts of the cut wire to the added wire. You can run the wire from any of the holes that are drilled from the fire wall into the dash.
Im not sure but that yellow wire might be the temp. switch wire.
If I didn't help or if i just mistook a bunch of stuff Sorry!!!
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
Old 06-17-2002, 12:17 PM   #3
CE20934
CE20934's Avatar
Location: Help! I'm in an office park with its own network of freeways!
The purple wire is indeed for the "S" terminal. The yellow is for points ignitions (runs from the "R" terminal to the positive terminal on the coil).
'67 C20--427 tall deck/SM420, 4.10 HO52 (Michigan has not been kind to the Old Man)
'95 Caprice--355 LT1/T56/3.42 8.5" 10-bolt (daily driver, almost 300k on the chassis)
'07 Outback--wife's car. 125k & counting. No head gasket or transmission issues yet. *fingers crossed*
CE20934 is offline   Reply With Quote
Old 06-17-2002, 02:02 PM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Definetly put the purple to the s terminal. The yellow wire is for putting 12V to the coil during starting only, once the key moves from start to run then you only have approx 9V on the coil.
For HEI disregard the above.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
