Old 05-28-2005, 09:27 PM   #1
82c10
needin' money
shaved stake pocket holes
how did you shave the stake pocket holes ? did you also fill in the hole at the bottom? pics please if you have them
82c10 is offline   Reply With Quote
Old 05-28-2005, 11:19 PM   #2
ureckme
ureckmefixit2@cox.net
I made a small plate the size of the hole and welded it in.
This should be in the paint/body section. heres a pic any way. Matt
ureckme is offline   Reply With Quote
Old 05-29-2005, 12:34 AM   #3
bagged_and_bodydrop
Just drag it
Did the same thing basically. I took some tape and put it on till I covered the hole with a lil extra on each side traced the hole out on the tape, took the tape off as one, put it on a piece of scrap sheet metal cut it out and then put a stud on the back to hold it, then spot welded it in, cut the stud off, grinded the welds down, and used some metal to metal over it. Then the basic body work. It's easy cause you can use the same template for all of them or at least I did. I'm no expert by far just a kid in body shop class. And I did fill in the holes just did the same thing basically.
bagged_and_bodydrop is offline   Reply With Quote
Old 05-29-2005, 10:15 AM   #4
bigblock73
yeller
bigblock73's Avatar
If you are shaving the stake pockets, go the extra mile and remove the actual pockets (boxes) that sit below the frame rails for a cleaner look. I plan on doing this on mine when I get to that point.
bigblock73 is offline   Reply With Quote
Old 05-30-2005, 04:54 PM   #5
rage'nrat638
rage'nrat638's Avatar
Heres My Hole Fillers
rage'nrat638 is offline   Reply With Quote
Old 05-30-2005, 05:28 PM   #6
86swb
Born a Chevy Man
86swb's Avatar
That does look good!
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66
*1986 Chevy SWB Silverado
*1984 Chevy Longbed Silverado
New Kia Sportage (Wife's car and she loves it)
CHEVY, American made w/pride!
If you can read this, YOU NEED TO THANK A TEACHER!
If you can read this in ENGLISH, PLEASE THANK A SOLDIER!
GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS
86swb is offline   Reply With Quote
