Low Buck 6 lug rotors
I had been looking for a cheap alternative to 6 lug rotors, so I would not have to switch wheels or rear axles, so after talking to member firstgen I figured what the hay and went for it. I got rotors for a 1990 3/4 light duty (7200 gvw) 2wd truck. The rotors use the same inner and outer wheel bearings as 71-up as well as the same seal. These are a direct bolt in as long as you have 71-up spindles, only one modification needed to be made, the rotors use a metric lug nut - $15 for twelve and the best part depending on where you get the rotors the price ranges from $43- $60 bucks- this beats $84 or more from other sources. Thought that some of you would appreciate this bit of info. Harold
67-72 parts collector,…
![]() Join Date: Nov 2002
Great TIP! How about some pics when you get time. Thanks,... lolife99.
What calipers do you use?
Rest in Peace Ed. Thanks for all the good times. |
Ed I am using 71- up calipers, the rotor is the same thickness as the rotors offered originally and as the 6 lug replacement- 1 1/4"- other than the difference in lug studs (1.5 pitch 14mm), I can't find any differences from 5 lug originals or the 6 lug replacements offered currently. The rotors are the same size and consume the same amount of space in the 80's model 4x4 rallies. I feel like I am going to have problems with the stock hard lines and the hoses coupled with the 69-70 crossmember. I got a great deal on new 69-70 hard lines but do not know what to do about the prop valve- other than bend new lines from the prop valve to the M/C and then adapt the hard lines to the prop valve.... Any ideas? Harold
Sisyphus was my mentor!
![]() Join Date: Sep 2002
Oh man this is a sweet thread! I just love ez conversions that are almost bolt-ons!
passthebuck ![]() #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
#6 | |
The LuvShack Garage
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
I'm wondering about how much fluid it takes to push the calipers as compared to the cylinders in the drum type? will your master cylinder work?
I got a bench seat baby, you don't have to sit over there. |
#8 | |
Just Don't Stop!
![]() Join Date: Feb 2004
The best part about it is that you can swap to 5 lug anytime with just a quick trip to AutoZone...
1968 C10 build in process TT LSA/6L90e/9" |
purple gas: I know that master cylinders do not interchange, but I'm not sure excatly why, BUT I think it's either more pressure and/or volume on the disc side....
Working on a Nova.
Actually from that I've heard is it takes less pressure on disc brakes than drum. Also if you should be able to fit a later model booster and master cylinder on our trucks just be using the old rod and brackets. As for Hard lines should be close from a later model truck also, I would try getting an old set from a junk yard for a couple of bucks and testing fit then order new ones for that year of truck. Just some thoughts and feel free to correct me if I'm wrong!
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
The calipers need more fluid volume ( bigger cylinder ) and the prop valve should be adjustable. the best thing is to swap master cylinders with the donor truck. Some of the board members say they have had no problems with the stock ones though.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Got Light Emitting Diode?
the disc/drum masters hold more fluid that the drum/drum ones. i was getting all my parts together to do my front disc swap when my master cylinder went out. i bolted a disc/drum one on and it feels just like it did before it went out
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
#13 | |
Msgt USAF Ret
master cylinder
#14 |
thats exacty what i am saying. just verifing that there is no pressure change between disc/drum and drum/drum masters. only a difference in volume of fluid
#15 |
Just Don't Stop!
Yeah, I second that. I bolted on a disc/drum master when I still had 4 wheel drums and it felt the same. By the way our 4 wheel drum trucks have no factory prop valve. You will probably want to get a universal inline valve like a wilwood or similar. They are only like 40 bucks. Otherwise, the back will lock up pretty easy.
