Old 05-28-2005, 10:41 PM   #1
mocwon
Keep On Truckin'
mocwon's Avatar
Unhappy Tuned port injection woes.....
Got all the wiring done, fluids in and cranked it over to get #1 TDC so I can stab the dizzy tomorrow. The in-tank fuel pump did not come on when cranking. I checked one of the fuse holders on the Painless tuned port wiring harness and what do you know the 30 amp fuse was blown. I put another one in and it blows. It even blows the fuse when the key is off. Anyone else been through this before? I fired off an e-mail to the Painless tech group for help to see what they have to say.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 05-28-2005, 10:59 PM   #2
neonlarry
neonlarry's Avatar
Sounds like you have a short, I would check the wiring to the fuel pump and make sure its not pinched somewhere. After that make sure the fuel pump is wired right. If you still blow fuses disconnect the fuel pump at the pump and make sure it's (the pump) not causing the problem.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 05-29-2005, 10:09 AM   #3
mocwon
Keep On Truckin'
mocwon's Avatar
Thanks, I'll check that out first....
Just Passin' Thru
