Old 05-28-2005, 11:09 PM   #1
crawdad
crawdad's Avatar
Question about Detent Cable
In a continuing quest to "de-hotrod" the truck I took off the hands of my nephew, I have discovered there is no passing gear. According to the numbers, this truck came with a 305 engine with a TH400 transmission. The 305 was replaced with a 350 engine, and the TH400 was replaced with a TH350. I believe the TH400 had an electric passing gear, but I think the TH350 uses a detent cable. Am I right on this? There is no cable on this truck, so if this is so, then can I simply connect a detent cable from the carb to the trans to fix this problem? Is there any compatability issues I need to be aware of? Thanks for any advice folks.
2012 Silverado LT 1500, 5.3, 6 speed auto
'86 SWB C-10 Silverado
crawdad is offline   Reply With Quote
Old 05-28-2005, 11:20 PM   #2
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
Yes, the TH350 uses a cable, and they are fairly cheap. The only concern is if you have the correct bracket up by the carb to connect the cable-end and sleeve.
NeCrOmAnCeR is offline   Reply With Quote
Old 05-28-2005, 11:31 PM   #3
crawdad
crawdad's Avatar
Could you expound on that bracket a little more? Does it mount to the manifold or to the carb? Is it still available from Chevy dealers or do you know where I might find one? Better yet, does anyone have a picture of the bracket? For all I know it might already be on the truck.
Old 05-28-2005, 11:59 PM   #4
NeCrOmAnCeR
The one on mine bolts to the back two carb bolts, hangs off to the drivers side of the carb and has the square hole for the kick-down cable to runthrough, as well as the throttle cable and return spring. Sorry, don't have any pics.
Old 05-29-2005, 01:49 AM   #5
jermasaurus
jermasaurus's Avatar
you should be able to get a universal one. companies that make chrome dress up kits, chrome dipsticks, they should make a bracket that bolts to the carb or intake. Do you have Pep Boys, or Murrays or Autozone near you? Their products aren't the best, but they carry a lot of that chrome stuff. Hope this pic works.
jermasaurus is offline   Reply With Quote
Old 05-29-2005, 07:39 AM   #6
76bonanza
76bonanza's Avatar
mine mounts to intake on back behind carb
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 05-29-2005, 11:29 AM   #7
crawdad
crawdad's Avatar
I went out and checked again, and there is a bracket. In fact, there's two brackets. One is mounted to the two rear bolts holding down the carb as NeCrOmAnCeR said, and the other is a chrome one that is mounted further to the drivers side on the manifold. While poking around back there, lo and behold, I found the cable laying down on the trans up near the firewall! I pulled it out but I can't figure out which bracket to put it on. The chrome one sits further to the drivers side than the other, which is up pretty close to the carb. Also, I don't see any way to mount the cable to the carb. There doesn't seem to be any attaching point. It's times like these that I'd give anything for a digital camera. If anyone has a picture (a good detailed one) of the intake/carb area with the accelerator and detent cable hook up, I sure would appreciate it. Any other help greatly appreciated.
