Old 05-29-2005, 12:06 AM   #1
shanetch
vin # ???
The vin number on my truck is CKE182S105116. I have figured the production number on the last six numbers. The problem is my cab doesn't have the rear view mirror spot above the windshield. So I think I have a 72 cab, but I don't have the door pillar release valve above the vin #. I know it was made at the St. Louis plant because of the S. The E stand for a v-8. The 1 stands for half ton. The K for 4x4. It's the 8 and the 2 that I have a problem. If the 8 is the year then what of the 2. It is either a 72 or a 68. Do the 4x4 have the CK like mine? Or just the K. Any help would be appreciated. I know that a 4 is a stepside and a 34 is a fleetside.
shanetch is offline   Reply With Quote
Old 05-29-2005, 01:09 AM   #2
pjmoreland
pjmoreland's Avatar
It's a 72. My truck is a 72 and the VIN starts with CCE142Z. The number before the factory code (Z) is the year.
pjmoreland is offline   Reply With Quote
Old 05-29-2005, 05:09 AM   #3
Rod
8 is the body style...in this case a blazer and the 2 is the year 1972.
The first C up front was for Chevrolet in 1972.
Its a Chevy 4x4 blazer 1972, eight cylider built in St Louis...or at least that what the vin decodes too. You mentioned a cab...hmm, somebody swapped something.
Your assuming a little to much with the 4 and 34 you wrote about..4 meant a box on a truck chassis...not what kind of box..could be stepside or fleetside.
34 does mean a fleetside...but not often seen on Chev vin numbers,,,more a GMC thing in their vins, but not always.
You would see the 34 in the model number on the glove box sticker typically on a fleetside truck Chev or GMC.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 05-30-2005, 01:54 PM   #4
shanetch
I thought that 6 was the blazer code number? Is there a book with all the codes? I am just trying to figure out what I have. The frame on my truck is a cut down. I bought a swb 4x4 frame and I found the numbers stamped under the door. Anyway, thanks for your help.
