Old 05-29-2005, 03:53 PM   #1
phanatic32212
It's Done When It Runs!!
phanatic32212's Avatar
Question Water Pump Questions
I am trying to diagnose my overheating problem. It won't boil over but it runs at about 210. The rad is cool to the touch while the engine is running. I just replaced the cap and the thermostat with a 180 degree but it still runs hot. When I check the pressure on the upper rad hose, it seems like the only pressure I get back is from the rubber hose pushing back. Water pump maybe? How much pressure should be on the top hose? Also what is the measurement for a short and long water pump? Thanks in advance.
Or Give Me DEATH
phanatic32212 is offline   Reply With Quote
Old 05-29-2005, 04:50 PM   #2
john
member #16
john's Avatar
Here is the diff between long and short pumps. I would check the temp with a thermometer , guage could be off. Also if you dont have pressure check the rad cap. John
john is offline   Reply With Quote
Old 05-29-2005, 04:59 PM   #3
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
i would check the radiator is the lower hose cold or hot ? possible plugged radiator and do you a fan clutch on ? are you using a shroud ? electric fan works great too
how many rows is the radiator ? hope this helps ya
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 05-29-2005, 06:24 PM   #4
Fred T
Cantankerous Geezer
Fred T's Avatar
Sounds like a thermostat issue, or a broken impeller on the water pump. Is the thermostat right side up? Pointed side goes up. Another possibility is a collapsed lower radiator hose. With the radiator cap off you should be able to watch water flow through the radiator once the engine is warm.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 05-29-2005, 08:20 PM   #5
phanatic32212
I went out and checked the hoses and other stuff as you guys suggested. Here's the rundown: lower hose is hot, I guess I don't have a fan clutch, as the fan spins all the time, I am using a shroud, and I think I have a single maybe 2 core radiator (it's only about 1 1/2" thick), thermostat is good it don't kick in until 180. I can see the coolant level go down once the thermostat kicks in. The pump shaft spins pretty smooth by hand, with no noise or anything. Any other suggestions?
Or Give Me DEATH
Old 05-29-2005, 10:15 PM   #6
VetteVet
Msgt USAF Ret
VetteVet's Avatar
The manual says you should feel the hose pulse back when you squeeze it if the pump is good. Like Fred says, pull the radiator cap and look for water flow. You can see the vertical columns of cores in the radiator,so just count them from front to back to see how many core rows you have. yours sounds
like a 2 core.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 05-29-2005, 10:34 PM   #7
GloryHound
Working on a Nova.
GloryHound's Avatar
Just a little Caution note that was not mentioned that could easily be forgotten remove the cap while the engine is cool. boiling hot coolant and skin do not mix. You probably already knew this, but I've heard of people doing stupider stuff who you thought would have known better!
Now as for the problem: The upper hose should be hotter than the lower hose since the upper hose is your return. If it is not then you are having circuation problems. Also are you using a good mixture of coolant to water, sounds dumb but pure water or pure coolant will not cool an engine as efficently as coolant and water at the right mixture for your area. Also what does the coolant and water mixture look like. If it has a heavy rust color you could have to get the engine and radiator flushed to remove the rust deposites that could be blocking passages not only in the radiator but the engine also.
GloryHound is offline   Reply With Quote
Old 05-29-2005, 10:59 PM   #8
phanatic32212
The coolant looks fresh (no rust or brown color), the pressure on the top hose is not as much as I think it should be. I guess I'll get a water pump tomorrow. Also, when I changed my gauges to the autometer ones, I didn't use the supplied sensor with the gauge, I just used the one that was already there. Could this be a problem? A sensor is a sensor, right? Thanks for all the help.
Or Give Me DEATH
Old 05-29-2005, 11:41 PM   #9
GloryHound
Working on a Nova.
GloryHound's Avatar
A sensor is a transducer that converts your 12V signal into a voltage that can be read by the meter for a given temperature. Nomally they are simular enough to use on all meters but also your old sensor could be bad and as I said normally they are interchangable, but who ever you bought the guage off of should be able to answer that question with thier tech support. Or you might just want to put the new sensor in and see what happens. They aren't hard to change on these trucks and the newer styles probably have a tighter tolerance if nothing else.
Old 05-29-2005, 11:43 PM   #10
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Very possibly because the sensor is nothing but a variable resistor to ground. The hotter the coolant gets the less resistance to ground. The gauge may be calibrated to the autometer sensor.
VetteVet
Old 05-30-2005, 08:47 AM   #11
70GMCer
70GMCer's Avatar
I would most certainly try that sensor before taking the water pump off.......
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 05-30-2005, 01:53 PM   #12
phanatic32212
Red face
I changed the temp sensor this morning...and VIOLA, gauges reads 180. Good thing I changed that before I chaged a water pump.
Lesson learned: Change out all parts supplied with the part you get.
Thanks for all of your help.
Jake
Or Give Me DEATH
