Old 04-12-2002, 04:22 PM   #1
Reumster
L.E.D. Freak
Reumster's Avatar
Question Running with the TB cable on a 700R4 adjusted wrong? What will happen?
I have benn driving my 700R4 with it adjusted wrong, and didn't know it. What happened is I bought one of them adjustable throttle/tranny cable brackets, and it was wrong, so what damage could this have done about 200 miles worth. I'm going to replace the fluid, and get it adjusted, what actually happens to the tranny if you run to long with the cable out of adjustment?
1972 2wd Blazer, 350/700R4/3:73 posi/NOS. Power is nothing without control!
Specializing in Custom L.E.D. inserts.
http://www.ccled.com/
Contact me @ blazer2wd1972@hotmail.com
(406)675-8082
or Joel @ jmcwaters@eps-corp.net
1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL
Reumster is offline   Reply With Quote
Old 04-12-2002, 04:27 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
It will poop out on you with little or no warning at all.
You would need a complete rebuild.
Make sure who ever does it for you, installs pressure guages and does it RIGHT
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 04-12-2002, 04:40 PM   #3
Reumster
L.E.D. Freak
Reumster's Avatar
Question
Does what? What does it actully do to the tranny? How does it effect it? I know when it was miss adjusted it would shift into 3rd very easy! Barely push on the gas going like 75 and it'd kick down.
(406)675-8082
Old 04-12-2002, 05:09 PM   #4
Longhorn Man
Post
I don't know what exactly it does, all I know, is it kills it.
The T.V. cable not only controls the down shifting, but also the fluid pressure. So if it isn't adjusted properly, it will not have the right psi to cool and lube it.
Old 04-12-2002, 06:03 PM   #5
Reumster
L.E.D. Freak
Reumster's Avatar
Question
Well good thing I run synthetic, and double coolers, with built on electric fan! LOL! But I better replace the fluid, and filter ya think?
(406)675-8082
Old 04-12-2002, 06:06 PM   #6
Longhorn Man
Post
yep...I'd do that first thing after the adjustment.
I can't remember who it was, but some one on here just had one crap out on him...same deal, TV cable. I think he said it lasted him 2500 miles...something like that.
Old 04-12-2002, 06:40 PM   #7
bigvinnie
bigvinnie's Avatar
Post
if it's only been 200 miles you probably haven't done a lot of damage.... just as long as you haven't been trying to burn rubber or stress the trans... longhornmail is right, it has to do with fluid pressure, lubrication and heat. The coolers you're running have probably helped to minimize more damage also. Get it dialed in and you should be OK....
Word to the wise: don't try to tow anything heavy while in lockup - that's how I fried my first 700R with less than 1000 miles on it... got it rebuilt, added a cooler and haven't had a problem since.
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
http://www.ixpres.com/vlusardi/chevtrk.htm
[This message has been edited by bigvinnie (edited April 12, 2002).]
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 04-12-2002, 06:50 PM   #8
Reumster
L.E.D. Freak
Reumster's Avatar
Thumbs up
you can tow with a well built 700R but must pull it manually into 3rd while pulling a grade.
(406)675-8082
Old 04-12-2002, 07:26 PM   #9
Littles72
Post
I set mine with a pressure gauge and have had no problens yet. I dont remember my presurres but I wrote them down and I will let you know. I have also heard different stories about the lock up. I tow a car trailer with a full size bronco all over the place with mine and have no problems in lock up. But mine is able to lock up in 3rd by manual switch. If I hit a long grade I drop to 3rd and flip the switch so I get no slippage and keep me temps around 175 or so but no higher. All I run is the stock cooler in the radiator. I love my trans as it is the best upgrade I have done to my truck. BUT It was also stressed to have that TV cable set up correct before any driving. Go to www.700r4.com If the site is up and running its pretty informative.
1972 short fleet and soon interchangable short stepside beds 2wd with 68 front clip
350/700r4/3.73s 15x8 Truck rallys with 235/275 60s
Orange and Black soon to be all Orange
Littles72 is offline   Reply With Quote
Old 04-12-2002, 07:51 PM   #10
bigvinnie
bigvinnie's Avatar
Post
yeah, I'm set up so I only lockup in 4th, so I learned an expensive lesson on towing....now it's 3rd only when towing.
72 Stepside Project
Old 04-12-2002, 08:21 PM   #11
Gordo
Talking
I have a "non-locking (no electronics)converter with a aux cooler in mine and have towed a 22' camper many hundreds of miles using all four gears. It's been over 40K and still works fine.
1971 C10 swb stepside 350/700R4/3.73posi
Killingworth, Connecticut
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03)
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1958 Massey Harris Pony
1951 Wife
May those who love us, love us, any of those who do not love us, may God turn their hearts.
And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping.
A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist.
Gordo is offline   Reply With Quote
Old 04-12-2002, 08:24 PM   #12
Longhorn Man
Post
IT is not recomended though. i have seen quite a few overdrive trannys die early from that. All makes too.
