Old 05-29-2005, 06:49 PM   #1
HugrOrang71
Bite me, import boy
HugrOrang71's Avatar
68 C10 LWB for parts
What seems to be going rate for a 1/2 ton parts truck? No engine installed, but comes with a running 350, 4 speed, has a few options. Ram assist steering, has 6 lug 16.5" wheels with factory hubcaps, no tach but full gauges, front clip seems to be in good shape, straight and minimal rust. Grille and trim is straight, hood letters all there. Cab isn't bad. virgin dash, Needs some body work under fuel neck, rockers appear solid, some rust starting in cab corners, doors are poor, good glass all around, bed sheetmetal is nice, needs wood replaced, frame appears solid from what I could tell.
Was looking to buy just the engine and trans, but the guy wants to get rid of the whole truck. Any ideas on what it's worth?
Jason
'71 C-10 Deluxe-under construction '69 C20, 396,T400-donor truck, '65 C10 project
"Facts are meaningless, You can use facts to prove anything that's even remotely true."
HugrOrang71 is offline   Reply With Quote
Old 05-29-2005, 07:41 PM   #2
racer face
In Ohio dollars thats 1000$ to 1500$.Thats not a parts truck in the rust belt, that one you rebuild.
Pat
______________________
1968 1 Ton Dually Flatbed 327/th400
1968 C30 Open Road 327/th400
1997 F350 CREWCAB 4X4 460 BIGBLOCK
racer face is offline   Reply With Quote
