Old 06-16-2002, 10:01 PM   #1
superchevy
Got big-block?
superchevy's Avatar
Put an AirLift Slam-Air set-up on my truck this...
morning. It's designed especially for lowered trucks. Those little airbags make a big difference in tow capacity. Now I can tow the boat or car hauler without dragging the frame on the axles
Fairly easy install, went quick enough to try it out and go to the lake.
Here's a pic of the truck and boat:
http://www.imagestation.com/album/?i...55389261&idx=4
If you're planning on putting one on your truck, email me and I can give you some tips I learned the hard way that will cut your install time down.
SC
'68 CST SWB factory 396/T400
buddy buckets, a/c, ps, pb
'72 Corvette convertible 454/4spd/ac, ps, pb
'73 GMC Sierra Grande short wide 454/T400 ps, pb, ac
'77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original
'78 GMC Sierra Classic short wide 454/T400 ps, pb, ac
'72 GMC Sprint SP454. 1 of 38 built.
'73 GMC Sprint SP454. 1 of 71 built.
'75 GMC Sprint SP454. 1 of 25 built.
SOLD! '72 GMC K25 4x4 468/4L80e/NP205
build thread
http://67-72chevytrucks.com/vboard/s...23#post4324423
SOLD!'55 Chevy gasser 496/4spd
build thread
http://67-72chevytrucks.com/vboard/s...96#post4324396
superchevy is offline   Reply With Quote
Old 06-16-2002, 10:12 PM   #2
Alexis
Member since 2000
Alexis's Avatar
dude addind any air bag to a lower truck wiht springs helps alot plus you can make in firm or "stock" ride. i will be adding airbags to britney cause i like the ride to be a little tighter
Alexis is offline   Reply With Quote
Old 06-16-2002, 10:22 PM   #3
superchevy
Got big-block?
superchevy's Avatar
Alex, I don't think the slam-air offers a firmer or "stock" ride option. It's just a small "helper" bag you inflate whenever towing or carrying a heavy load - a glorified airshock, basically. It mounts between the frame and leaf spring.
I plan on keeping it basically deflated (10psi) whenever I'm not towing so my a##end isn't sticking up in the air.
SC
build thread
build thread
Old 06-16-2002, 10:26 PM   #4
Alexis
Member since 2000
Alexis's Avatar
yeah i use to install those thing all the time. on 2002 trucks with flip kit and stock. most system tell you to keep the bag with at least 15psi min if not in use, eibach offers a system that you but a bag within the coil to plant the tire a little better. there are other comanys that offer the same thing. and that what i'm going for. it not at much loose and stiffens up the stock suspsion on the rear.
Old 06-17-2002, 09:28 PM   #5
Low69CST
Those are also used alot to counter Axle torque. I think the passenger side is made stiffer to fight the twisting of the driveshaft.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
