Old 05-29-2005, 07:10 PM   #1
FuelCellGuy
FUEL CELL GURU
FuelCellGuy's Avatar
6-lug to 5-lug axle swap
I bought a pair of 5-lug axles from a board member that was supposed to be a direct swap with the 6-lug axles. They didn't work. The splines on the 5-lug were smaller than the 6-lug splines. Could the 5-lug be 73-up axles?? Later, FCG
FuelCellGuy is offline   Reply With Quote
Old 05-29-2005, 07:15 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
That's odd. The only differance I was aware of was the length. The 73 & up ones (so I've been told) are the same as the 71/72.
I wonder if they were out of something other than a 12 bolt?
Old 05-29-2005, 09:27 PM   #3
Rod
Should be 30 spline by 31 15/32 length...same axle 1971-1980 from a 12 bolt truck or 2wd blazer/ Jimmy.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 05-29-2005, 09:31 PM   #4
uncle
Axles
Some early (63-64)? trucks came with coarse spline axles.
uncle is offline   Reply With Quote
