05-29-2005, 09:02 PM | #1 |
User #12137
wireing woes
today i was driving the 67 and then it just sputterd ( it was like i cut the key off )and died ,huh i thought, so i hit the key to crank it back up and nothing i was really like wtf now so i coasted to the side of the road and got out to take a look to see what happed . ok the frist thing i looked at was the red wire from the battery to the junction box( had it brake there once and the truck did the same thing ) , it was good shape ,battery in good shape , everything looked good, so i got out the test light. and went to pokin around got power on the red wire to the fuse block and got power to the starter ( should there be power on the little wires in there ? )and got power at the alt , no headlights , no power to anything inside the truck
so to get home i hot wired it (hot wire from the alt to the hei and crossed the stater with a screw driver and it ran, so home we went now i got to figer out whats wrong with it the truck is a 67 with a hei and internal regulater alt i did the wireing for all that years ago and cant remember whats what ? , i am getting old and losing it so i think i need a wiring diagram of the wireing under the hood for all that stuff to see whats messed up in there ? what do you all think |
05-29-2005, 09:49 PM | #2 |
Msgt USAF Ret
Well since you got it running by jumping the starter it rules out the fuel syatem and the primary wiring I.E. the large cables to the starter and the ground cable. The fuse block has power but no lights or key switch. sounds like the firewall connector may be loose. Anyway here is the diagrams for the 67 to 72s.Good luck and keep us posted.
http://www.geocities.com/chevroletc1070/wiringdias.html
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
05-29-2005, 09:51 PM | #3 |
There are two fuses in the harness right behind each headlight..Check those,One in for the alt,other for headlights
05-29-2005, 09:56 PM | #4 |
Did you put a guage dash in place of the light dash?
How did your taillights harness fry? And i have some complete harnesses here for light clusters if you want to start over...I hate electrical troubles!!!!! |
05-29-2005, 09:57 PM | #5 | |
User #12137
the wireing harness block is tight aready checked that but i didnt take it apart to look at it but i will tommarow and see whats in there !! |
05-29-2005, 10:00 PM | #6 | |
User #12137
05-29-2005, 10:01 PM | #7 |
I am going to johnson city tuesday with 2 junkers and mail packages and will get this harness up to you..To keep a fellow member's ol' 67 sb on the road...
05-29-2005, 10:05 PM | #8 |
User #12137
i got a question just how many wires sould be hooked to the starter ? the battery wire and the purple wire and then mine had a red wire to it but it was not hooked to anything on the other end it was just laying there ?
05-29-2005, 10:09 PM | #9 |
You only need the one to the inside (motor side) of the starter. Come over here and get your guage harness/engine harness from a 72 V8 guage truck
05-29-2005, 10:10 PM | #10 |
User #12137
if i can find a way to get there yea i will
05-29-2005, 10:15 PM | #11 |
You can get over here . And see if those tires are still there and i will buy them..
05-29-2005, 10:17 PM | #12 |
User #12137
i will have to check on the tires i havent be able to catch the dude at home
05-30-2005, 12:47 AM | #13 |
I would recommend disconnecting the headlight wiring harness from the firewall, and check to make sure you have 12 volts on the big fat red wire that provides power to the inside of the cab. If you don't, then a fusible link is probably blown (the one that bisquik65 mentioned). The fusible link is taped inside the wiring harness near where the alternator regulator mounts. I was upgrading a truck awhile ago with a gauge instrument panel, so I was replacing the headlight wiring harness with one that had the wires for the amp meter. The truck was totally dead like yours. I finally discovered that the fusible link was broken (not fried). The previous owner of the harness had patched in longer wires for reaching across the engine to an alternator mounted on the passenger side (long water pump), and had not supported the fusible link well enough. I'm guessing that a few years of road vibration fatigued where the wire attaches to the fusible link, and it finally cracked off. Once I repaired the connection to the fusible link, the truck started right up.
05-31-2005, 01:18 PM | #14 | |
User #12137
ok i have been out there missing with the wires lol and the big fat red wire has power to it so i pulled the plug apart and looked in there and the red wire conector looks like its been hot and the fuse block is discolored there around it so i would say that was the problem thanks to eric i got a complete used harnness ,headlights ,under dash ,motor, tail lights and its for a gauge dash witch i was going to change to anyway now i got sum questions 1 is there any differances in a 69-72 harness than a 67 one ? if so what are they? 2 am i letting this harness swap intimidate<sp? me or is it easyer that it looks ? |
05-31-2005, 04:20 PM | #15 |
User #12137
nobody knows this ? |
06-01-2005, 12:53 AM | #16 |
There are a few differences in the dash harness.
1) The parking lights do not turn on with the headlights for 67 2) The windshield wiper knob is on the left side of the gauge cluster on 67 and on the right for 69-72 so the wires in the harness for the wiper switch come out of the harness in a different place 3) The fuse panel is mounted sideways for 67 so the wires come out of it in different directions than for 69-72 4) 67 doesn't have the ACC position for the ignition switch I installed a 69-72 dash harness in a 67 once when I was upgrading to an instrument panel with gauges. The only painful part was that I had to make some modifications to get the wiper switch wiring to reach the wiper switch. From then on my parking lights were lit when my headlights were on. |
06-01-2005, 09:07 AM | #17 | |
06-01-2005, 11:49 AM | #18 | |
User #12137
ok cool cause i got a 69-up gauge dash, with comaro tach, i want to put in anyway !!!!!!!! and with the harness thats there and the one i got from eric i can make the modifications fairly easy , i think |
06-01-2005, 11:51 AM | #19 | |
User #12137
now you want to come over here and help me with the harness change |
06-01-2005, 12:07 PM | #20 | |
