05-29-2005, 11:58 PM | #1 |
72 BB C30 Super LongHorn
72 Rear Leaf / 10-bolt question
Hi all!
Will a 1973 & up 10-bolt Truck 1/2 ton axle drop into a 1972 rear leaf spring chassis? Was wondering if the 10-Bolt will line right up to the Truck 12-Bolt rear axle mounting/etc....Thanx!
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS |
05-30-2005, 07:11 AM | #2 |
Spring pad spacing is different.
Shock mounts are different. 10 bolts use a Saginaw S44 u-joint and 12 bolts use a Spicer 1310. 10 bolt rear axles are '81 and up only - prior to that they still used 12 bolts.
Tim |
05-30-2005, 07:56 AM | #3 |
RPOZ11 Been meaning to post to you and ask how the cab change out is going on the longhorn?
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper 72 bug(the better half's) under reconstruction 2009 HHR aqua blue 71 GMC k20 350/sm465 2009 Chevy hd3500 6.6 Victory Red crew cab dually Dave & Jeanne |
06-01-2005, 07:00 PM | #4 |
I put up 3 pics today, look in the 67-72 message board under C/30 Disc tag
