Old 05-30-2005, 07:53 PM   #1
mocwon
Keep On Truckin'
mocwon's Avatar
Talking The tuned port roared to life!!!
Turns out I had the wrong oil pressure switch and the ECM was damaged. But, today the tuned port came to life. I'm a happy lad and the engine has now been through the initial break-in. Special thanks to neonlarry for trouble shooting help. Now, its time to get busy and finish putting it together for summer fun in the sun....... and 100+ degree heat.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 05-30-2005, 07:59 PM   #2
neonlarry
neonlarry's Avatar
That's cool, now I have to get one of mine in and running. If you get a chance how about some pics, you have to show it off.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 05-30-2005, 08:00 PM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
Congrats on getting it running!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 05-30-2005, 08:20 PM   #4
MikeS
Active Member
MikeS's Avatar
Congrats! I'm really jealous. I'm still in the gathering parts stage of my TPI conversion. I did manage to modify the '87 intake to fit my old heads and painted it today. Parts are trickling in, hopefully I'll get it put together by mid-July.
I need an oil pressure switch too. Where did you get it? Part #?
MikeS is offline   Reply With Quote
Old 05-30-2005, 09:01 PM   #5
71swb4x4
71swb4x4's Avatar
Congrats on getting it going. Mine has been running for almost a year and I love it.
MikeS
I am pretty sure that Arizona Speed and Marine has an oil pressure switch that will work with our mechanical oil pressure gauges.
http://www.azspeed-marine.com/
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 05-30-2005, 09:58 PM   #6
mocwon
Keep On Truckin'
mocwon's Avatar
I bought it from Advance Auto Parts #OPS110, $7.97 plus I had to buy a 1/4"F to 1/8"M adapter. You should be able to find it just about anywhere. I put a tee in so I could run a mechanical oil pressure gauge.
neonlarry,
I'll post some pictures once I have it more presentable. It's kind of a mess right now after all the trouble shooting.
Just Passin' Thru
Old 05-30-2005, 10:50 PM   #7
Russell
Professional Grade
Russell's Avatar
Congrats man!
I am getting really close to firing my TPI up for the first time too I already broke the engine in on a carb, so if I have issues, I won't be risking my cam :P
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 06-01-2005, 02:37 PM   #8
Ackattack
Ackattack's Avatar
I've gotten mine to fire up twice, but I'm having problems. I think the oil pressure switch or wiring to it is bad. My switch is plugged in right above the oil filter (87 TPI) so I think it got fried on the headers in the vehicle i got it out of (but the funny thing is that it was running fine)
Ackattack is offline   Reply With Quote
Old 06-01-2005, 04:27 PM   #9
71swb4x4
71swb4x4's Avatar
On my 86 TPI my oil pressure switch was behind the distributor. I bypassed my oil pressure switch because I didn't have room for it with my engine in the 4x4 position. When I put my 700r4 in I am moving my engine to the 2wd position and I will put the oil pressure switch back in.
Old 06-01-2005, 05:47 PM   #10
Ackattack
Ackattack's Avatar
what kind of fuel mileage are you getting with your tpi/7004 combo? What gears are you running?
Old 06-01-2005, 05:53 PM   #11
Super Duck
Chevy Nuttttt
Super Duck's Avatar
Hey how about some pics? I am getting ready to start that swap but am waiting untill I get the paint and boby work finished. One thing at a time.
67' Chev swb step side
69' SS elky
03' Chev ext cab 4X4
hey who lernt me to spell
is there anything else?
Super Duck is offline   Reply With Quote
Old 06-01-2005, 07:10 PM   #12
Deuce
Deuce's Avatar
Cool!! I SHOULD be ready to fire the 383 TPI in a couple weeks. Doing a blazer tank swap too for the return line.(Don't want a high pressure fuel return line running inside the cab!!)
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
Old 06-02-2005, 01:12 AM   #13
classicchev
classicchev's Avatar
Seems like the thing to do. I finally receive the last box of my TPI purchase off Ebay, now I just have to find time to work on it. Too many projects, not enough time.
67- 72 Parts collecter
classicchev is offline   Reply With Quote
