Old 05-30-2005, 09:59 PM   #1
4X4K1500
33" fit on '68 k20
on my dads '68 k20 he's redoing will it be possible to fit 16x10s with a 33" sts on it?
It clears the 17.5" and pizza cutters by a mile.
If necessary with a ORD Zero Rate work in the front?
and wat could we do to make them fit? all the lifts are for 69-up??
4X4K1500 is offline   Reply With Quote
Old 05-30-2005, 10:13 PM   #2
GMC71k20
a friend of mine has a 71 k20 on 33s with stock leaf springs all around and they fit but look somewhat stuffed
GMC71k20 is offline   Reply With Quote
Old 05-30-2005, 10:51 PM   #3
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
If I can get 33's under the back of my 2wd C20, you shouldn't have any problem getting 'em under a 4wd. I'm running two 33/12.5/16.5 MudKings on stock rims in the rear and they fit under there OK. I haven't pulled a heavy trailer or hauled a big load yet, so I really can't tell for sure. Right now without anything in the bed there's about 5" of clearance between the tire and wheel-well. My truck has the G50 option HD rear coil springs so it kinda keeps the bed up high.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 05-31-2005, 01:39 AM   #4
breeh
Recovering 67-72 Addict
breeh's Avatar
I had rubbing problems under full stear with 33's on a factory K20. I was running BF Goodrich tires. Some have posted here that they have not had problems. I think that it depends on the tire manufacturer ( 33" does not neccessarily mean that they are), the amount of backspacing, and how much suspension sag you are dealing with. Good luck!
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 05-31-2005, 07:30 AM   #5
4X4K1500
the wheels are pretty wide at 16x10
Old 05-31-2005, 09:19 AM   #6
chevyfarmer
chevyfarmer's Avatar
67 2wd short box with original Heavy Duty rear coil springs
15 x 8 GM ralleys with 33 x 12.5 tires on rear
without load was fine, with minor load (300lbs) it was a rubber.
67 short wide 355ci 3 on tree
69 short wide 250ci 3 on tree
68 long wide 283 3 on tree
72 2wd Blazer project 454 5 speed
chevyfarmer is offline   Reply With Quote
Old 06-06-2005, 02:45 PM   #7
70blazerpickup
im running 33 12.5 bfg mudterrains on 15x10 rims on my 70 blazer with no problems. i think they would fit on a 3/4 ton with no problems.
70blazerpickup is offline   Reply With Quote
