Old 05-30-2005, 10:04 PM   #1
jamal
jamal's Avatar
stripped crank
I know I ask more questions than I contribute, but hopefully one day I can return the favor. Anyway, my feter in law stripped his threads for the harmonic balanancer bolt. How can he fix this? It is a new engine, so would rather to not have to remove crank
jamal is offline   Reply With Quote
Old 05-30-2005, 10:34 PM   #2
Randy70C-10
Randy70C-10's Avatar
Tried installing the balancer with the balancer bolt eh? That's a big no-no. If he only pulled the first couple of threads out, he'll be ok, but he needs to get some all-thread the same size as the bolt and install the balancer by running a nut with the balancer washer down the length of the all thread to push the balacer onto the crank. The all thread should be drove into the crank until it bottoms out before doing this.
Randy70C-10 is offline   Reply With Quote
Old 05-30-2005, 10:48 PM   #3
Russell
Professional Grade
Russell's Avatar
The tool that Randy mentions is extremely easy to make if you have access to a welder. Just buy the fine threaded bolt he needs to fit into the crank, then weld another long bolt on the back side. Then using a combination of big nuts, thick washers etc, pull the balancer back onto the engine. Much safer, and works like a charm!
As far as the stripped crank goes -- How far down is it stripped? My crank is stripped about half way down due to me wrecking threads trying to get a busted harmonic balancer removal tool out, yet it is just fine. If you have enough threads to get the balancer on, then red locktite the other bolt in, it should not be a concern. Early SBC didn't even have a bolt holding the balancer on!
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 05-31-2005, 01:40 AM   #4
HugrOrang71
Bite me, import boy
HugrOrang71's Avatar
If the threads have only been pulled out on the first few turns, you can get a longer bolt that will bite into the undamaged threads.
If there is no saving the existing threads, I would heli coil the crank and install a new bolt.
Jason
'71 C-10 Deluxe-under construction '69 C20, 396,T400-donor truck, '65 C10 project
"Facts are meaningless, You can use facts to prove anything that's even remotely true."
HugrOrang71 is offline   Reply With Quote
Old 05-31-2005, 01:49 AM   #5
krue
Designated A-hole!
krue's Avatar
If you can use a longer bolt, do it, otherwise heli coil.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 05-31-2005, 03:15 AM   #6
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
Longer bolt.Helicoil works good too,but hte longer bolt is cheaper.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 06-01-2005, 01:59 AM   #7
jamal
jamal's Avatar
Thanks for all the replies. Yes, he tried installing balancer with the bolt. I looked and it is only stripped maybe a third of the way. Where is a good place to buy a longer bolt? I have only been a member for a couple of weeks, and am already an addicted member. I love this board, and will keep everyone posted on my 67 stepside progress.
Old 06-01-2005, 06:22 AM   #8
HugrOrang71
Bite me, import boy
I get my bolts from the bin at work . Most cities have a fastener distributor that will sell to the general public. A decent parts store should be able to get what you need. Another great place to find bolts is a Caterpillar dealer. I think I used a bolt that was 1/2" longer than the OE one the last time I ran into it.
Jason
Old 06-01-2005, 08:14 AM   #9
krue
Designated A-hole!
krue's Avatar
Napa or any Ace Hardware store should have what ya need.
www.daveramsey.com
Old 06-01-2005, 11:00 AM   #10
Fred T
Cantankerous Geezer
Fred T's Avatar
Go to a hardware store, farm store or auto parts store. You should be able to get a grade 8 bolt the length you need.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 06-01-2005, 11:48 AM   #11
flip66
flip66's Avatar
Some parts stores rent a balancer installer and once you get it on if its not bad striped you will still be able to use your origanel bolt.
1998 Pontiac Grad Prix GTP
1969 C10 396 TH400 3.08 posi
flip66 is offline   Reply With Quote
