05-31-2005, 01:07 AM | #1 |
Professional Grade
Header Flange Stiffeners
Who was it that was making the header flange stiffeners on the forum? They were three peice units that were about an inch thick, They went around head side of the flange, and forced the flanges to seal tightly rather than leak like headers always do. I'm sick and tired of leaking ticky exhaust, so I wanna buy a set of these things to make things work a bit better!
Also, do you guys have any tricks for making the head to header seal better? I straightened the flanges out the best I could using a straight edge. Would using double gaskets work?
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) Last edited by Russell; 05-31-2005 at 01:09 AM. |
05-31-2005, 01:14 AM | #2 |
Ok, here's how I fixed mine about 15 years ago. I cut each flange twice. Once each side of the center tubes. The flanges are probably warped from welding the tubes on. Then I used the metalic manifold gaskets with the little ears on the sides to catch the bolts. There are 3 gaskets for each side. Tighten bolts and forget about em. In 15 years I have had 1 bolt come loose and I dont think I got it tight in the first place. Trust me.
05-31-2005, 01:18 AM | #3 |
Professional Grade
Sounds like a good plan, I've already got some metallic manifold gaskets, so I think I'll give your idea a shot! Worth it, seeing as they are fairly inexpensive headers
I would just weld the pipes straight to the collectors, but the collectors are much larger than the pipes are, lol That and it would be a huge pain in the butt if I ever had to take the exhaust off...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) Last edited by Russell; 05-31-2005 at 01:19 AM. |
05-31-2005, 01:24 AM | #4 |
I never had problems with my collectors leaking.
05-31-2005, 01:52 AM | #5 |
Professional Grade
My collectors leak worse than the head to header connection. When I first did the exhaust on that truck, I bent the triangles, DOH, leaked ever since, and there is no way I can get them straight. Thats why I was hoping I could find some flange stiffeners
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
05-31-2005, 03:00 AM | #6 |
driving is in my blood
Cheap headers leak, exspencive headers don't. Headman elite's have 14g tubing and 3/8" flanges, those thing will never warp unless you do somthing very very bad to them. They also use the ball and flange collector, those seem to work very well. They also cost $279 last time I looked for a 78 c10 SB. I have the standerd headmans, and they leak at the collector a little bit no matter what gasket I use. They only cost a little over a $100 too
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
05-31-2005, 07:51 AM | #7 |
Born a Chevy Man
I have always doubled up on header gaskets and have had no problems.
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66 *1986 Chevy SWB Silverado *1984 Chevy Longbed Silverado New Kia Sportage (Wife's car and she loves it) CHEVY, American made w/pride! If you can read this, YOU NEED TO THANK A TEACHER! If you can read this in ENGLISH, PLEASE THANK A SOLDIER! GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS |
05-31-2005, 12:53 PM | #8 |
For collectors and header to head:
Use better hardware and gaskets. Use locking nut and bolts like stage 8. Use copper and the stock type donut gaskets.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * |
05-31-2005, 01:37 PM | #9 |
On my headers (Hedman) I straightened the triangular flange and then had it mig welded to the header on the engine side of the flange . I then had the collector flange welded on the exhaust side of the flange . After that I ground off that little ring that they actually use to seal against the gasket . This way the entire gasket surface is used to seal . The reason I did this is because that in how the flanges and collectors on my $500 Hooker Super Comps are done . It makes for a much better seal . The truck they went on never had a collector leak . The only difference is that mine were off . You would have to spend an afternoon removing yours to do this but I think it will solve the problem for good . Frank
05-31-2005, 01:59 PM | #10 |
Professional Grade
Another good idea frank! My pipe flanges are welded on solid, but the headers are not. I've got the headers out of the truck right now, and it is very easy to put them in / take them out. So I'll weld those flanges up against the pipe as well. I can probally get them fairly straight. I like your idea of flattening the gasket too -- That should help a fair bit!
Thanks for all the good advice all!
05-31-2005, 02:58 PM | #11 |
I'm using stainless bolts in the heads and they are soft so you can't really get down and tighten them like the regular header bolts. They still stay tight, after cutting the flanges. My collector flanges are welded. You can see the cut in the flange in this pic. It's not a big deal, but it does work. Oh and it makes getting the bolts started easier too.
05-31-2005, 03:11 PM | #12 |
Mudder67 .. Nice Engine compartment .
Russell .. I know you have thought of this , but make sure that you align the bolt holes in the flanges before welding .. Frank |
05-31-2005, 03:17 PM | #13 |
05-31-2005, 03:40 PM | #14 |
Professional Grade
hehe, yeah, amazingly enough I did think of that!
Often times that is the type of thing that I would forget though :P
05-31-2005, 03:54 PM | #15 |
Monroe...thanks. As much as its driven its hard to keep that way.
05-31-2005, 05:41 PM | #16 |
Copper gaskets.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
05-31-2005, 10:42 PM | #17 | |
Right turn Clyde
Have any pictures or illustrations?
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
05-31-2005, 11:04 PM | #18 |
I dont have the truck anymore . Take a look at this link
http://www.holley.com/HiOctn/ProdLin.../f4201HKR.html Here is exactly what they look like when you weld them as I am talking about . You can see it perfect in this link . http://www.holley.com/HiOctn/ProdLin...f11030HKR.html You can kinda see the flanges I am talking about . There is not that little flared ring that the collector rotates on . You weld it on the side opposite of the flared ring and then grind that ring off . Make sure the flange is straight (flat) first . On headers with the rotating flange , the only thing that the gasket seals on is that little 3/16th's inch flare . That is why they blow out. This way the entire flange clamps the gasket since they are the same size .If anyone has a closeup of a Super Comp, and can post a picture of the collector flanges , it would show you exactly what i am talking about since that is where I got the idea . Frank Last edited by f.monroe; 05-31-2005 at 11:10 PM. |
05-31-2005, 11:24 PM | #19 |
Right turn Clyde
Sounds like a good idea, but im still a little lost on what is getting cut off.
06-01-2005, 12:33 AM | #20 |
Oh,you can't buy that new
Hi-heat silicone sealant. DAVE
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone 73 Pinto, stock, w/CragarSS's-eww LOTS of Cummins trucks. |
06-01-2005, 12:46 AM | #21 | |
06-01-2005, 07:05 AM | #22 | |
Born a Chevy Man
06-01-2005, 08:07 AM | #23 | |
LET IT SET UP A FEW HOURS BEFORE YOU FIRE IT UP! I had a set that were soooo bad once on a small block that I cut the flanges and had to run double thick gaskets on the center ports. DAVE
06-01-2005, 08:25 AM | #24 |
I'm with Jerermy. I've the same setup on my headers no leaks for three years
82 C-10 Scottsdale LB owned since 89 350 crate vortec heads Crane 1.6 full rollers edelbrock 1406 edelbrock performer eps intake dynomax headers/flowmaster 70's BTO 700r4 level 3 custom 2 piece driveshaft 12 bolt gov loc w/3.08 |
