Old 05-31-2005, 08:50 AM   #1
1980 Chevy
1980 Chevy's Avatar
Gauge/Bezel Question
What's the scoop on instrument gauges/bezels? I have a 1980. Are all 73-87 interchangeable?
1980 Chevy is offline   Reply With Quote
Old 05-31-2005, 09:13 AM   #2
86 GMG
yes they are all interchangable but you will find a little difffrents in the windshield wiper/washer knob are diffrent on a few years some trucks had them on the turning signal and some were in the dash
square body trucks an addiction or an investment either way they consume all my extra time and money
86 GMG is offline   Reply With Quote
Old 05-31-2005, 09:25 AM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
NO, they are not "all" interchangeable. Although they will fit, that does not mean they will work. I'll have to post the details later since I'm trying to leave my office now. There are quit a few changes made through the years at are very important....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-31-2005, 09:51 AM   #4
1980 Chevy
1980 Chevy's Avatar
Looking fwd to reading about those differences N2Trux. BTW- Nice truck!
Old 06-02-2005, 09:09 AM   #5
KShortell
KShortell's Avatar
The bezel will vary a little based upon whether the truck had A/C or not (has to do with the vents), was in a year with the wiper control on the dash or on the column, had brushed aluminum, woodgrain, or was plain. Note that The brushed aluminum and woodgrain are basically factory appliques (stickers) over the base model bezel.
The LMC catalog actually does a pretty good job in showing the differences over the years.
Good luck!
Semper Paratus
KShortell is offline   Reply With Quote
Old 06-02-2005, 09:15 AM   #6
1980 Chevy
1980 Chevy's Avatar
I sort of felt that KShortell...but just wanted to make sure before I spend the big bucks on a new brushed alum one for my truck.
Thanks for the reply.
Old 06-02-2005, 12:40 PM   #7
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
The aluminum is cover is split 73-77, 78-80, 81-87.
They are listed here, but the pic is the same for simplicity.
http://www.73-87chevytrucks.com/merc...tegory_Code=7G
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 06-02-2005, 01:00 PM   #8
1980 Chevy
1980 Chevy's Avatar
Yea, that's what I'm talking about...they all LOOK identical, but for some reason they are split up between the years you've listed. Thanks Capt.
Old 06-02-2005, 01:18 PM   #9
bigblock73
yeller
bigblock73's Avatar
The only real difference is the diameter of the gauge openings. I believe LMC has their diameters in their catalog. If you are going to put in aftermarket gauges, get the one with the largest openings. They still won't be big enough, but you still have less to trim off.
bigblock73 is offline   Reply With Quote
Old 06-02-2005, 04:19 PM   #10
86 GMG
1980 chevy sorry for the miss leading i just learned something myself today. boy those ele. gauge set really would look sweet in our trucks wouldn't they anyway have a good day
Old 06-02-2005, 04:23 PM   #11
1980 Chevy
1980 Chevy's Avatar
No worries 86 GMG, that is what is cool about this site..we all learn something every now and then....there are all kinds of parts that are soooo close, but for one reason or another may not bolt in. I have the same questions regarding front grilles. I really like the older ones....and they look close, but just not sure if the bolt holes are in the right place, etc...
Thanks for the info bigblock73...I'll keep that in mind.
Old 06-02-2005, 07:56 PM   #12
Captkaos
Captkaos's Avatar
To clarify, the trim plates ARE different, I just listed on pic for each piece. Jeff listed the actual difference which is the diameter size.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 06-02-2005, 09:35 PM   #13
TrainD5115
North Coast, baby!
TrainD5115's Avatar
I put a 77 bezel in my 79 and it fit about 90% correct. It had clearance issues on the lower side of the bezel and the lower column covers did not interchange. As stated earlier, they can be made to work but it will look a tad off. Ended up buying a used correct year for my truck (78-80) and am alot happier.
Brad
79 Scottsdale C20
350/350
3.73's
Still running full CA smog gear!
TrainD5115 is offline   Reply With Quote
Old 06-03-2005, 02:17 PM   #14
KShortell
KShortell's Avatar
I only know that 'cuz I did the ChevyDuty replacement aluminum decal deal. I'm not all that thrilled with it, so I bought a new bezel. The old one's OK, I'm just anal retentive that way and I got a killer deal on a new one that was too good to pass up. I'll have the old one for sale sooner or later, though...
Semper Paratus
