OK I need a fuel cell with sender.
What are you guys useing for fuel cell.
I've never had a sending unit with my fuel cell, but now my cell is to old to upgrade. I want a fairly large cell with a sending unit Where to get one? Anybody have a good used one? Cheers, and thanks agian.
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
most people with a plastic cell get it from Summit They sell a 16 gallon with a sender pretty cheap! If you have the extra cash get one from Fuel Cell Guy here on the board!
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
I have a 20 aluminum gallon cell with sender. 24x20x12. I ordered a ECE rear crossmember that way I could run the rear sump at the rear. It hangs a little low but just as low as a blazer tank. Are you planning on putting it in the bed ? or under. Stop by your local speed shop and see what they have.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
My old one was under the bed, then I put it in the bed for more room under there.
Mainly for painting reasons to get the bed off easy. My local speed shops are pretty shady. I'll check summit and see what they have. |
Take it from my experiance. Just shell out the big money and get one from Fuelcellguy. If you really think about it it's not that bad.
