Old 05-31-2005, 03:38 PM   #1
1969K10
1969K10's Avatar
67 sheetmetal part on 68
So, i have a 68 cab, with 69 qtrs, hood & what's left of the front grill (purchased this way). Since i've gotten no takers on the 67 i'm needing to get rid of, i'm looking at swapping the front qtrs, hood & grill onto my 68 cab. Is there anything that i need to be worried about as far as things fitting and lining up? From what I can figure, it should be a bolt-on issue.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 05-31-2005, 03:52 PM   #2
smokekiki
Mike
smokekiki's Avatar
You say quarters,do You mean Fenders?You need the 67-68 radiator support,fenders hood and grill.If it has 69 fenders on it now,You need to use the whole front clip from the 67.This is assuming You are refering to a chevy.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 05-31-2005, 03:59 PM   #3
XXL
Seņor Member
XXL's Avatar
'67 and '68 sheetmetal are interchangeable.
XXL is offline   Reply With Quote
Old 06-01-2005, 04:37 PM   #4
1969K10
1969K10's Avatar
So how do I tell if I've got at 68 radiator support, or a 69? Right now, as best as I can tell, I've got 69 fenders. I know what remains of the front grill is 69, and the hood is 69 & up... The radiator support should be 68 (?), because my headlights don't sit centered in the openings of the grill...
Old 06-01-2005, 04:59 PM   #5
CPNE
Resident Curmudgeon
CPNE's Avatar
A 67 or 68 chevy radiator support will have a series of nuts welded to the rad support across its bottom front edge whereas a 69-72 will not. This is because 67/68 trucks had a valance piece that filled in the area between the lower part of the grill and the lower front edge of the rad support. These nuts accomodated the bolts that held the valance in place.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 06-01-2005, 06:21 PM   #6
Super Duck
Chevy Nuttttt
Super Duck's Avatar
as long as you pull one front clip and repalce it with another you will be fine
67' Chev swb step side
69' SS elky
03' Chev ext cab 4X4
hey who lernt me to spell
is there anything else?
Super Duck is offline   Reply With Quote
