Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > Review Board > Vendor Reviews
Old 05-29-2005, 01:29 PM   #1
MARTINSR
MARTINSR's Avatar
Exclamation Spot weld driller Shoot out!
Spot weld driller Shoot out.
Spot weld drilling comes up on the forums quite often. Being I had the opportunity to use a couple of the best tools for the job I thought it would be a good thing to report on.
I have a very nice tool, the “Dentfix” Spitznagle spot annihilator, but it is out of the average hobbyists price range at about $400.00, with the two optional “clamps” it is about $540.00.
I have seen a cheaper version of the tool under the Astro name and had wondered if it did the job. Well, today one of my co-workers came to work with one. I had a pair of quarters to replace on a 2002 Chevy pickup. So, I used the Astro on one side and the Spitznagle on the other.
Astro
http://search.cartserver.com/search/...ords=AP%201756
Spitznagle
http://www.toolsource.com/ost/produc...ASVVDEQCBEDSL3
(I have no affiliation and do not recommend these companies, use at your own risk, posted for example only)
I found that the Astro is a pretty good tool for the money. It works very similar to the Spiznagle and will “do the job”.
The first thing you have to understand is that using one of these tools is SOOOOOOOO much better than any other way to remove spot welds you are floored the first time you use one. So either tool will seem REALLY nice the first use, you will be very surprised how valuable a tool it is if you do this for a living. After a few jobs you want to bend over and let someone kick you in the butt for being so cheap and not buying one the first time you saw it. It is nearly effortless to use. It is sort of like a hand held drill press. Only the drill press requires you to pull down on the handle to apply pressure for the drill to go into the metal. These spot weld drills actually apply the pressure for you. Just place the tool into position and pull the trigger, the bit goes forward while it is spinning and applies the pressure needed to send it into the metal. Not only that, the depth of the hole is determined by how deep you told it to drill! This is a very cool tool. It is not “needed” as a regular hand drill will to do the job, but it is very welcome that I will tell you.
I have to say the Astro is miles from the Spitznagle in ease and quality of operation. One of the good things about the Spitznagle is that the bit turns very slowly with lots of torque. This really lets the bits last a long time. The Astro spins almost as fast as a high speed drill, it will likely burn up bits. It didn’t cut nearly as fast, not even close. It seemed that the bit would burn up before it would get the cut done. However, it did seem to cut about as well at the last weld as the first, so that may be more illusion than anything. I did put the more expensive Spitznagle bit in the Astro to see if that would improve the cutting, it didn’t.
The biggest draw back to the Astro is that it only came with one medium sized clamp. I do not know of the others are available, if they are not, this is a problem. I use the three different clamps (the tool only comes with one just as the Astro) I have for my Spiznagle on most all big jobs. You need the different depths of access for the different welds all the time. The bigger clamps are too clumsy for many places and you can’t even get in there. The smaller ones are of course too short to get the bit back to the weld to drill it without hitting on something preventing you from reaching the weld. Without the clamps the Astro has a serious disadvantage, if the clamps are available it would be a fair replacement for the higher priced Spiznagle for someone on a budget. Remember with the Spiznagle the clamps are extra, about $60.00 and $80.00 apiece as I remember. So the price for everything I used in the test was about $540.00, quite a jump from the $200.00 for the Astro. It wasn’t fair that I had the extra clamps for the Spitznagle while doing the test. But I wasn’t going to torture myself for this test and not use them. The point is the clamps make a BIG difference. If they are available for the Astro that would move the Astro up quite a bit.
Understand, you don’t have to use the clamps, you can remove them and use the tool like a normal drill. That is how I removed the welds with the Astro that I couldn’t do with the clamp in place.
The Astro also has a strange way they hold the clamp on, it is a pin sticking out of the drill and a slot in the clamp. You slide the clamp over the end of the drill and then rotate it to lock in behind the pin. The Spitznagle has a spring loaded clamp that clips over a ring on the tool. You can rotate it anywhere you want at any time to position the drill over the weld. This is the problem with the Astro; You need to rotate this clamp all over to gain access to different welds. The Astro clamp would fall off once in a while as I was rotating it into position. Now, if I was using the tool every day, I am certain I would get use to where this would happen and avoid it. But I think it would limit where you may be able to put the clamp and that of course means the tool is limited.
Ok, that is an unbiased observation of my test. By the way, I not only did the test myself, I asked others who tried the tool for their feedback. One in particular thought nothing of my complaints with the Astro and felt it to be nearly equal to the Spitznagle.
However, this is my opinion; you don’t have to have one of these tools. If you are a home hobbyist it is a pure out and out luxury. Don’t buy either, save the money for more needed tools. If you are a pro, for goodness sakes buy the Spiznagle, it is well worth the money. By the way, I started writing this about three weeks ago. Since that time, the guy who brought the Astro has found it unsatisfactory and returned it in exchange for a Spitznagle.
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
