![]() Join Date: Nov 2003
Deuce - TPI air ducting pictures
Deuce -
Here are the pictures of how I ran my ducting on my Mass Air TPI. I bought the 90 degree elbow from www.jagsthatrun.com It has a 3" inlet and 4" outlet. I bought another 3" x 3" 90 degree elbow and I planned to route the air cleaner a bit further away but it works real well where it's currently at so I haven't changed it.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Thanks for the pics. I have them saved now!! I'm running the Mass Air on the 383 and was tinkering with a few different ideas for a "cold air" system for the air intake.
I know what your thinking.......I have ESPN. ![]() Sometimes it's easier to do things the hard way. ![]() Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!! ![]() ![]() |
I'm going to have to get that elbow for mine. I have this flex tubing stuff and it has to hurting the power.
Check out Air Flow Systems. They have rubber elbows and reducers and metal 90's among other stuff. Look under the headings in the left side. Specifically "Rubber Hoses and Clamps," "Exhaust Elbows'" and "Intake Tubing."
'68 Short Step LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc |
Keep On Truckin'
I'm about at the point of adding ductwork to my TPI. Thanks for the leads
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
I was going to find some ducting that was factory, but then I can't run a engine driven fan. Only electric fans, which I haven't had the best of luck with in the 5L Mustangs.
I think JTR is the way to go!!
