Old 06-01-2005, 09:24 AM   #1
Hunter
Lovin' Arizona Since 1961
Hunter's Avatar
Cruising the Neighborhood, Found a '72 C65 For Sale
It has Coors logos on it, needs work, cabover, gasoline power. Single rear axle with mongo dually's on it. Power is a 366 big block. Anybody know anything about these engines? There's no bed on it, the beer transport box was removed and put on another truck when this one was retired probably. Would make a MONSTER flatbed. I'll get some images next time I drive by it. The sign says $3200 but its been there awhile. Anybody want info? Original Arizona Coors truck! H.
"Religion is like a toothbrush: Everybody should have one, but I don't want yours" - Will Rogers
Hunter is offline   Reply With Quote
Old 06-01-2005, 09:34 AM   #2
chevyfarmer
chevyfarmer's Avatar
Cool! the 366 is a big block v-8 motor that GM used in heavy duty applications like the c-65. It was pretty common in school busses in our area but most of them are diesel now. I have a 366 that runs on propane in a c-70 grain truck on the farm. A huge PITA best describes it, i would much rather have the gas. If you could post a pic that would be great.
67 short wide 355ci 3 on tree
69 short wide 250ci 3 on tree
68 long wide 283 3 on tree
72 2wd Blazer project 454 5 speed
chevyfarmer is offline   Reply With Quote
Old 06-01-2005, 10:21 AM   #3
Russell
Professional Grade
Russell's Avatar
366 big block will move anything, but not quickly by any means. Our school's bus has one, and I've fixed it more than a couple times -- But it also has half a million miles on the clock. Usually a problem with the dizzy, a coolant leak, or some accessory going south. I've never heard of it having any mechanical work.
The thing is a real dog though, barely gets that poor bus moving. I tried to convince the school to let us in the mechanics class soup it up, but they said no
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
