Old 06-01-2005, 09:37 AM   #1
shelby987
shelby987's Avatar
C vs. K
Okay, I am a newbie, but I was pretty sure that the C series of truck C10, C20, C30 was 2wd, and the K10, and K20 was 4x4. I am constantly seeing trucks being sold that are listed as C10's and C20's, but that are also running 4x4 drivetrain. Am I missing something special about the K series....should I assume that a truck listed as a C series that is 4wd is either being listed by someone who doesn't truely know what their truck is....or its a 2wd on a 4x4 frame? Or were C series trucks sold with 4wd from 67-72????
shelby987 is offline   Reply With Quote
Old 06-01-2005, 09:43 AM   #2
Paul72
Paul72's Avatar
A factory "C" series truck should be 2wd, however, there are Custom/10 and Custom/20 as well as CST/10 and CST/20 trucks that can be either. Blazers are a different story - all Blazers are K/5 whether 2 or 4wd.
I'm sure someone else will chime in with more info.
Paul
'72 Chevy K20 - 383/4sp/205 - SOLD after 41 years in the family
Next project - K/5 Tahoe (71 Blazer on 99 Tahoe chassis) Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=789958
Paul72 is offline   Reply With Quote
Old 06-01-2005, 11:14 AM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I believe the difference is the model number on the glove box door v. badging.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 06-01-2005, 12:51 PM   #4
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
Also, they never made any K badges, except for the K/5 Blazers. So a 4x4 3/4 ton truck will have C/20, Custom/20, or CST/20 emblems, and a 2wd 3/4 ton truck can have the same.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 06-02-2005, 12:59 AM   #5
roger0080
After 33-38 years of surving, by now alot of these trucks could be pieced togther.
I have seen many "4WD's" with a 2WD VIN number.
Even though it's 4WD it could have been a 4WD from day one where someone later does a cab swap from a 2WD. In which case the actual title VIN would be correct yet.
So when you see a 4WD with a "C" Model number and not a "K", heads up! something funky is going on.
And vice-versa, you could have a 2WD with a 4WD cab put on it.
72 Chev C-10 90% restored (former AZ truck) ...
71 Chev K-20 Cheyenne my vacation crusier...
72 Chev C-10 Now retired and striped after many faithful miles...
72 GMC 1500 Retired to the junk yard after bought new in '71...
roger0080 is offline   Reply With Quote
Old 06-02-2005, 01:01 AM   #6
roger0080
... quick follow up, from the factory you won't get a 4WD truck with a "C" series designation in the VIN or Model; It will be "K' if 4WD.
Old 06-02-2005, 06:54 AM   #7
Blazer1970
Blazer1970's Avatar
Bottom line is that the fender badges don't mean anything when it comes to 4 vs. 2wd. The C or K in the first position of the VIN (or the second position on a '72) DOES indicate 2 or 4wd.
Blazer1970 is offline   Reply With Quote
Old 06-04-2005, 02:54 AM   #8
Americanrider
My truck has the stock C-20 emblems on the fenders, but I call it a K-20 because thats what my VIN starts with, KE2xxxxxxxxxx I not sure when GM started using the K for the truck, sometime in the late 70's I think.
When in doubt..... check it out! GMC Pauls VIN decoder page.
http://www.gmcpauls.com/chevrolet_data.htm
http://www.gmcpauls.com/67-72_chevy.htm
Americanrider is offline   Reply With Quote
