Old 06-01-2005, 01:58 PM   #1
Back in Black
Fuel Guage doesn't work
I recently hooked up my instrument panel on my frame off truck. With the help of some board memebers, I figured out that my panel wasn't grounded correctly and I now have most guages and and all lights working correctly.
My fuel gauge still doesn't work. I have power to the dash via the fuel guage feed wire. Power is supplied when the key is turned on. I have the brown wire from the fuel guage sending unit plugged into the fuse box where indicated. The guage doesn't move when I turn on the key. I have half a tank of gas.
Any suggestions??
Jason
Back in Black is offline   Reply With Quote
Old 06-01-2005, 02:58 PM   #2
Putter
More Cowbell....
Putter's Avatar
Depending on if the gauge ready full or empty, your brown wire is either gounded to metal, or is cut/broken somewhere along the way. Turn the key on, then reach behind the seat and pull the wire off the sending unit. Look at the gauge and see where it is. It should be headed towards the full mark. Then ground the wire directly to some bare metal. The gauge should run the opposite way and stop at or below empty. If the needle doesn't change position, then you might have a bag gauge itself.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 06-02-2005, 01:39 PM   #3
Back in Black
I'll try it
Thanks for the advise putter. I will try it tonight.
jason
Old 06-02-2005, 07:34 PM   #4
jef5150
Inline 69
jef5150's Avatar
lots of solutions here, to different types of gas gauge problems http://www.chevytrucks.org/tech/gasgauge.htm good luck, jeff
jef5150 is offline   Reply With Quote
