Old 06-01-2005, 02:46 PM   #1
PETEM1957
Junior Member
Quick Question - 4x4 With Big Block
Was A Big Block Ever Offered In The 4 X 4 Version Of 67 To 72 Trucks With Automatic Or Manual Transmissions? All References I've Seen Are Two Wheel Drive Only. I Had A 1969 Lwb Two Wheel Drive That My Cousin Now Has. I Now Have A 1970 3/4 Ton Lwb M/t With A Semi Tired 350 In It. I Have A Fresh 396 That I Would Like To Install In It. But All References In Parts Books,say For Header Applications Exclude The Big Block In 4 X4 Applications Especially With A Manual Tranmission. Anyone With A Way Around This Issue??
PETEM1957 is offline   Reply With Quote
Old 06-01-2005, 03:52 PM   #2
meathead95
computer illiterate
meathead95's Avatar
bbc was never offered in a 4x4 try sending yukon jack a pm he just put a bbc in his 4x4 with headers and a 4 spd
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 06-01-2005, 04:48 PM   #3
bisquik65
bisquik65's Avatar
You can use a BB in with amanual trans and headers,You just need to read the footnotes under the header # Thats where i found out,You need 73-85 non hydralic clutch linkage,you will need the rod from the pedal to the z-bar...the z-bar itslef,and the frame bracket...and you need to cut a hole in the cab lower that you orignal one by about 3 inches...Thats all,rest is a botl in, You may have to Dimple the friewall on the pass side for valve cover clearance... I have done this swap before took the truck apart and put the LS6 454 in my 65 Biscayne...
bisquik65 is offline   Reply With Quote
Old 06-01-2005, 07:20 PM   #4
402Bowtie
402Bowtie's Avatar
Good question....What needs to be done to have a BB with an automatic trans?
402Bowtie is offline   Reply With Quote
Old 06-01-2005, 09:00 PM   #5
Roberty
Hot Damn - Here I Am!!
Roberty's Avatar
I'd venture a guess that an automatic swap would be easier. I have a friend who used to have a '69 4x4 with a 396 and automatic. Just be sure to use the big block motor and frame mounts.
My vehicles:
'90 Silverado Sport
'71 Chevelle SS Convertible
'70 C-10 - My Grandfather bought it new - original un-restored
Roberty is offline   Reply With Quote
Old 06-01-2005, 09:20 PM   #6
MAC67
" SHOW ME"
MAC67's Avatar
all of the ones i have owned or built i put big blocks in , you dont need to use big block motor mounts or towers or frame crossmember ect , if its just going to be a fun cruiser depending on the size of your valve covers you will need to put to small dents in the fire wall , maybe the size of a golfball for valve cover clearance only , if you are running a body lift it is easier , or you can move your mounts an inch or 2 forward and elimnate the need for altering the firewall
MAC67 is offline   Reply With Quote
Old 06-01-2005, 11:40 PM   #7
BAD4X4
BAD4X4's Avatar
I used Hooker super comps on my 70 chev 4x4 4-speed. The part # is 2817 and -1 for ceramic coating. Mine fit Killer. This is like the 4th set of hookers like this I have used. Hope this helps.
1972 Cheyenne K-30 6"lift {502 PROJECT}
1972 Cheyenne K-30 8"lift 454 450hp {Ol'Blue}
1972 Cheyenne K-20 Custom Stretch 6" lift 454
1972 Custom Deluxe K-20 4" lift
2007 GMC Crew Cab Diesel 6"lift {The Tow Rig
2017 Ford F-350 Crew Cab 6.7 6"lift (Wife's)
1977 El Camino SS Grandpa baught new
1986 K-30 Crew Cab 502
1955 Chevy 2-Door gasser 454 550hp{project}
1956 Chevy Bel-Air 2-Door hardtop 572 700hp
1979 Ford F-350 All Original 4x4 (Wife's)
BAD4X4 is offline   Reply With Quote
Old 06-02-2005, 12:10 PM   #8
Yukon Jack
Yukon Jack's Avatar
Here the link linky to the headache I had on fitting my bb. You will find some people that have to do not firewall mods at all, some that do a little and others that have big problems. I still don't understand why it varies.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is online now   Reply With Quote
Old 12-16-2024, 08:24 PM   #9
shane0331
shane0331's Avatar
Re: Quick Question - 4x4 With Big Block
Hey Yukon Jack,
Thinking about taking on this headache. Would love to go back and review your experience. Seems the linky no longer works. Any chance you could re-post it? Thanks a bunch!
shane0331 is offline   Reply With Quote
Old 12-19-2024, 11:08 AM   #10
dennislbrooks
dennislbrooks's Avatar
I think I read that the first BBC in a chevy 4x4 pickup was in 1977 but in 1 ton trucks.
I moved the motor mount perch forward 1 inch when I put my 402 BBC in my 67. Has a 700R4 with a NP208.
I like the motor mounts/clamshells/perches from a BBC 2wd square body. There will be some issues to resolve. Like Yukon Jack, I raised the engine 1/2 inch on mounts. You will be playing with other clearances. I did not have to modify the firewall and I run a Hydro boost.
https://www.67-72chevytrucks.com/vbo...d.php?t=615038
1942 Chevy 1/2-ton Rod, 1959 GMC 1/2 ton Fleet Step side, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T, 2018 Bolt
dennislbrooks is offline   Reply With Quote
Old 12-19-2024, 01:55 PM   #11
Yukon Jack
Yukon Jack's Avatar
I don't have an active website but I was able to get the page to load on my computer and at least take screenshots.
Old 12-19-2024, 01:57 PM   #12
Yukon Jack
Yukon Jack's Avatar
Here are the photos
Old 12-19-2024, 01:59 PM   #13
Yukon Jack
Yukon Jack's Avatar
Last pic.
