Fuse Questions
How big is the fuse supposed to be on the passenger side fender ground. This is inside the engine compartment, near the battery.
Also, I am hooking up an HEI distributor and electric choke. Someone said in another thread I can wire these to my "Ignition Unfused" - does this mean that I need to have an inline fuse on this as well? And how big does this one need to be? |
Are you talking about the fuse in the rubber case with black wires? 4amp.
For the HEI, yes on the inline fuse 15-20amp. Do not put the choke on the same wire.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
yeah, the rubber case is what I was after. Thanks. I thought the HEI and e-choke could be on the same wire?
