06-01-2005, 06:12 PM | #1 |
Truck won't turn over in park
'79 C20, 454/TH400...
Got in the truck today to park it somewhere else, wouldn't start in park. Starter didn't budge and no clicking. Put it in neutral and it started. I'm guessing there's a bad nuetral start switch somewhere. Where is this switch and what do I need to do to fix it? |
06-01-2005, 06:26 PM | #2 |
Enormous Member
Did you check your battery terminals and also check your positive wire that connects to the starter........
"79" Chevy Stepside 350/350 Check my Blog @ www.BaldMikesWorld.blogspot.com |
06-01-2005, 06:31 PM | #3 | |
06-01-2005, 06:50 PM | #4 |
Enormous Member
Never assume when it comes to something as simple as connections.
It's easy enuff to check both those fixes 1st........
06-01-2005, 07:12 PM | #5 |
Professional Grade
Yeah, there is a switch at the base of the column that probally went bad on you.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
06-01-2005, 07:18 PM | #6 |
Right turn Clyde
Even if they are good wouldn't hurt anything to clean them up with a terminal cleaner and wire brush then reinstall them.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
06-01-2005, 11:01 PM | #7 | |
Insert Witty Text Here
Cleaning the cables never hurts, and has fixed probably 75% of the "no start" problems I have ever had. Slonaker |
06-01-2005, 11:05 PM | #8 |
driving is in my blood
Thats the nuetral safety switch if the problem is on going, no doubt.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
06-03-2005, 01:32 AM | #9 |
Might be just a bit out of adjustment. Try moving the shifter just a little bit up or down while you turn the key.
06-03-2005, 02:10 AM | #10 |
I'm back with 2nd truck!
The guys are right. I've had this problem a couple times happen to me when I'm in neutral. The neutral safety switch is located at the base of the steering column right at the floorboard. It has 4 wires going to it. It will only let you start the truck in either park or neutral. Quick and easy fix. Take the wired in connectors off and then I think there's 2 screws. Take it out and replace with a new one.
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
06-03-2005, 03:29 AM | #11 |
Can I just cross a few wires and disable the switch? I'm smart enough to only start it in park.
06-03-2005, 12:20 PM | #12 | |
06-03-2005, 01:10 PM | #13 |
Stepsides RULE
yeah you pretty much gotta throw it into park for mine to catch. My sis drove my truck and she gingerly shifts (i laugh my ass off at it) and she never puts it all the way.
this is how she shifts. (from park) R..... N.......D (from drive)N..........R........P this is how I shift RND NRP
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD 1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD 1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD 2009 Kawasaki KLX-250S too many mods for this signature 1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake Cardomain of the Accord Last edited by cliffsta; 06-03-2005 at 01:11 PM. |
06-03-2005, 03:03 PM | #14 |
Pull the wires off of the switch that is mounted on top of your steering column (inside the cab by the firewall) and put a jumper wire in between them, the dang truck will start. Don't bet on the remembering to put in park to start everytime, I thought that myself until I got in a hurry and started it and took off down the drive ONCE---Never again.
Sean Midwest All Truck Nationals, Riverside, MO - 2008 - 2015 |
06-03-2005, 05:13 PM | #15 | |
06-05-2005, 12:36 AM | #16 |
Some of those switches also work the backup lights. Two wires are for the BU lights, & the other two are for the starter.
