TOTY 2006
![]() Join Date: Dec 1999
Picture of van tilt plug adapter PLEASE!!!!
Could someone post a picture of the wiring plug adapter that
you use to plug a truck wiring harness into a Van Tilt column? Does anyone have the part number as well? |
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
Chevy Nuttttt
I might have one in the garage.
67' Chev swb step side 69' SS elky 03' Chev ext cab 4X4 hey who lernt me to spell ![]() ![]() |
TOTY 2006
Thanks Larry!!
What I want to do is remove the wires from the flat plug, and rewire them into the horseshoe plug. Even willing to by the adapter just to make sure I get the wires right, and then I would resell the adapter. (Still hoping that someone can post a close up picture of the adapter) Super Duck? If you find it, can you post a picture? |
I won't have my camera back till sat. I can take a pic then if you still need one.
Here you go.
I think the terminals are different on the van plug. I started mine, and then realized that they van terminal would not go into the horseshoe. I haven't started to look for the correct terminal. If worse comes to worse I will cut them off with about an inch of wire and solder the right terminals on. I am pretty sure the terminals should be pretty easy to find though.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
I got the old 3 one the tree I was going to rob the other end off of,, any tips anyone?
I got a bench seat baby, you don't have to sit over there. |
The ends are definitely different. The horseshoe ends are square shaped as shown above. The van ends are a flat blade style on the end of the turn signal wires and slotted recepticle on the adapter end.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
TOTY 2006
well, it looks liek the wiring is a one for one swap on the plugs, now off to the electronic store to see if they have the correct plugs (the square ones as Bob mentioned).
Thanks all!!! Really appreciate all of your help. It is hard nowadays to get to the junkyard for researcing this stuff now that I have a little guy to look after. |
