Majician
Need a overall front end measurement, C20.
I am going to pick up a 1981 C20 and I need to know if it will fit on my trailer; I don't want to travel all the way there and have it not fit. Does anyone know the outside of tire to outside of tire measurement of the front of a C20 with stock wheels and tires?
Until Seventy Times Seven
I don't have the outside tire to outside tire measurement, but from outside fender to outside fender is 79.6". BTW, the wheelbase of a long bed is 131.5" with a overall length of 211.8". Oh, and a curb weight of just over 4,000 lbs.
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
Majician
Thanks for the reply. My trailer measures 75" wide between the rails, so it may fit.
be sure to check the off set of the rims on the truck i have a set of cicclr wagon wheels and my truck will not fit at all on a utility trailer (side rails) good luck and be carful with the truck hauling
square body trucks an addiction or an investment either way they consume all my extra time and money |
Professional Grade
Yep, make sure you take some pizza slicer wheels / tires to fit on there, helps a lot with getting them on!
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
My '77 C20 has stock 16.5 inch wheels with stock-size 9.50R16.5s on the front. If you want a measurement, PM me.
Real Name - Brandon Current Vehicles: 1977 C20 Silverado 454/TH400 3.73s 1989 Jaguar XJ6 in the middle of an LT1/4L60E swap |
I have aftermarket (wider) wheels on the truck, the outside thread to outside thread is about 75" and sidewall to sidewall is about 77". With stock wheels, you may just make it as long as the trailer fenders (if it has any) don't get in the way.
If it is a tight fit ,roll the window down first, you may not be able to open the truck doors once it is on, the door(s) may hit fenders on the trailer.
Air up the trailer tires to about 45# Trailer weight AND truck weight!! Good luck and make sure that it is tied down well! Just my .02 CCDually ![]() Last edited by GMC1tondually4dr; 06-02-2005 at 05:19 PM. |
Majician
Thanks everyone for the replies. The truck has stock 16" wheels so it should fit.
