06-02-2005, 03:55 PM | #1 |
Out draggin'
What is this? Never saw one before....
Ok, I need some education fella's... What is this? It's says its an "upper radiator hose pipe" but I've never heard of one. Is this an option or was it only available on certain models or ???? Are they hard to comeby as I have never seen one before.
Thanks... Joe
91 GMC Xcab LB-Bags/bd/caddy clip SOLD 72 C10 Cheyenne Super LWB SOLD 92 GMC K1500 Burb 72 C10 Burb (ex. Cheesewagon)SOLD 72 C20 Burb parts truck 71 C10 Burb "project" |
06-02-2005, 03:56 PM | #2 |
More Cowbell....
Got me. I look forward to an answer myself.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
06-02-2005, 03:57 PM | #3 |
Post Whore
Both of my K20 and my K5 use that pipe as a portion of the upper radiatior system.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
06-02-2005, 03:59 PM | #4 | |
The LuvShack Garage
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
06-02-2005, 04:00 PM | #5 |
Post Whore
Here's a pic of it installed.
06-02-2005, 04:07 PM | #6 |
72 Cheyenne
upper rad hose
My buddy's Blazer has one, he says it's original.
06-02-2005, 04:50 PM | #7 |
its all about the +6 inches
all 67 - 72 4X4 trucks are supposed to have that.
06-02-2005, 05:19 PM | #9 |
71 Cheyenne SWB Fleetside
why do they make special things like that for 4x4's? why would they need them over a 2 wheel drive unit?
thats stupid. joel
06-02-2005, 05:21 PM | #10 |
the engine is set back further, and the rubber hoses in the 60's pretty much sucked.
06-02-2005, 05:40 PM | #11 |
Mike
Take a look at the fan shroud in the pic.It is a lot bigger than a 2wd,to compensate for the set back engine.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
06-02-2005, 06:06 PM | #12 |
graphic designer
i had one of these. the weight of it vibrating tore the upper outlet off twice. i replaced it with rubber hose, all but a 4" section (the hose was too short), then replaced the rad with a '95 unit. almost a bolt it.
06-02-2005, 07:30 PM | #13 |
Out draggin'
Ahhh. That would explain it. Well, if I ever see one in person, I will be sure to take notice... Thanks fella's... Learned something new today...
06-02-2005, 07:55 PM | #14 |
~Rest In Peace~
i need one of those for my blower motor
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
06-02-2005, 09:33 PM | #15 |
20' Daredevil (Ret)
Late to the party again, but it's on my stock '72 K20. Makes it a lot cheaper to replace the upper hose - you only need two short pieces...
06-02-2005, 09:42 PM | #16 |
Had one on a 66 c20.
06-02-2005, 10:07 PM | #17 |
I saw one on a '71 GMC in a junk yard the other day, first time I had ever seen one, I thought maybe it was a GMC thing.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
06-02-2005, 10:20 PM | #18 |
blood type; Retumbo
wasnt that supposed to keep the hose out of the fan under frame twist conditions?
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
06-03-2005, 07:09 AM | #20 |
Doesn`t weigh any more than hose.More rigid.4-wheelin`is slow and and flexy.Heat build-up/soft hose.Think I`ll chrome one.
06-03-2005, 08:57 AM | #21 |
Powder coated mine~! Gloss black. Got new GATES hoses on both ends. LOOKS SWEET~!
06-03-2005, 11:48 AM | #22 | |
graphic designer
